clutch rattle/rumble??
Posted: Mon Jun 18, 2007 9:00 am
by choppa7
When the cars standing on idle there is a rattle/rumble from the underside which goes away when I press the clutch in, obviously its hard to tell if its happeneing when driving due to road noise and other rattles.
I recently replaced the clutch and release bearing and everything was fine but it only seems to have started in the past couple of weeks (did clutch about 1.5 month ago now.
Is the clutch just settling in or have I managed to f00k it already do you think?
Re: clutch rattle/rumble??
Posted: Mon Jun 18, 2007 9:05 am
by bazza93
could be the centre bearing ! got the same problem
done mine yesterday, or could be the doughnut !!
Posted: Mon Jun 18, 2007 9:09 am
by Demlotcrew
Thats called gear box chatter.
Posted: Mon Jun 18, 2007 10:16 am
by choppa7
Demlotcrew wrote:Thats called gear box chatter.
is it normal and harmless or does something need fixing?
Posted: Mon Jun 18, 2007 10:27 am
by Shinobi1
choppa7 wrote:Demlotcrew wrote:Thats called gear box chatter.
most of them do it and unless its deafing it seems to do no harm ,i belive its the layshaft bearings ? anyway mine did it for 100k of hard use and never got worse or let me down either
Posted: Mon Jun 18, 2007 10:46 am
by smithy318i
I wouldnt worry about it.
I dont', and mine sounds like its ready to fall to bits...
Posted: Mon Jun 18, 2007 10:50 am
by choppa7
nice one. One more thing off the worry list!
Cheers lads!
Posted: Mon Jun 18, 2007 11:12 am
by theflop
I think have qa similar noise on idle so hope it's that too.
Also when I set off from spped bumps at low revs in 2nd there is often a slight noise. I think it is from the gear box or clutch??????????? any ideas for that. It does worry me a little
Posted: Mon Jun 18, 2007 6:07 pm
by Andyboy
it's gearbox chatter or to be more specific the layshaft bearings. Nothing to worry about.
