clutch rattle/rumble??
choppa7
Mon Jun 18, 2007 9:00 am
When the cars standing on idle there is a rattle/rumble from the underside which goes away when I press the clutch in, obviously its hard to tell if its happeneing when driving due to road noise and other rattles.
I recently replaced the clutch and release bearing and everything was fine but it only seems to have started in the past couple of weeks (did clutch about 1.5 month ago now.
Is the clutch just settling in or have I managed to f00k it already do you think? :?
1990 318i Lux
bazza93
Mon Jun 18, 2007 9:05 am
could be the centre bearing ! got the same problem :( done mine yesterday, or could be the doughnut !!
will be back in an E30 oneday soon !
THE BMW 3-SERIES. IT'S WHY SOME ENTHUSIASTS ARE MORE ENTHUSIASTIC,
Demlotcrew
Mon Jun 18, 2007 9:09 am
Thats called gear box chatter.
choppa7
Mon Jun 18, 2007 10:16 am
Demlotcrew wrote:Thats called gear box chatter.
is it normal and harmless or does something need fixing?
1990 318i Lux
Shinobi1
Mon Jun 18, 2007 10:27 am
most of them do it and unless its deafing it seems to do no harm ,i belive its the layshaft bearings ? anyway mine did it for 100k of hard use and never got worse or let me down either :D
smithy318i
Mon Jun 18, 2007 10:46 am
I wouldnt worry about it.
I dont', and mine sounds like its ready to fall to bits...
choppa7
Mon Jun 18, 2007 10:50 am
nice one. One more thing off the worry list! :D
Cheers lads!
1990 318i Lux
theflop
Mon Jun 18, 2007 11:12 am
I think have qa similar noise on idle so hope it's that too.
Also when I set off from spped bumps at low revs in 2nd there is often a slight noise. I think it is from the gear box or clutch??????????? any ideas for that. It does worry me a little
Andyboy
Alpina Colada
Mon Jun 18, 2007 6:07 pm
it's gearbox chatter or to be more specific the layshaft bearings. Nothing to worry about.
