Removing drivers side wishbone
Posted: Sat Jun 16, 2007 5:09 pm
by Gravy
Does anyone have any hints or tips as to how to undo the nut on the main stud of the control arm balljoint that fixes to the subframe on the drivers side? Everything is off bar that nut and the exhaust manifold seems to be in the way to get a socket down giving enough turning clearance (m40 by the way)
I'm completely out of ides short of removing the engine!
Re: Removing drivers side wishbone
Posted: Sat Jun 16, 2007 5:15 pm
by hoshy
I think I used two long 1/2inch extension bars with a universal joint.
Posted: Sat Jun 16, 2007 5:26 pm
by smithy318i
hoshy wrote:I think I used two long 1/2inch extension bars with a universal joint.
So did I.
22mm socket/UJ/extension/extension/breaker bar.
if that doesnt work, use a nut splitter.
Posted: Sat Jun 16, 2007 5:34 pm
by Gravy
Cheers lads I can't beleive that didn't actually cross my mind, the UJ I mean!
Posted: Sat Jun 16, 2007 6:59 pm
by andye30nut
i did mine 2 days ago from the top if you get a long enough extension bar it comes undone no probs. long extension bar with a flex end job done mate
Posted: Sat Jun 16, 2007 9:29 pm
by Gwynleym10
I actually found it easier to jack the engine up a bit and take the engine mount out.
