Removing 2DR REAR Seat
Posted: Wed Apr 20, 2005 4:18 pm
by Project_E30
I need to remove my rear seat its a 2dr. The seat is cloth and has head rests if that makes any difference.
Can anyone tell me how to do this and is there any advice?
Posted: Wed Apr 20, 2005 4:26 pm
by Ziggy
Assuming it's not a really early one, the base just unclips as you pull it up (pull at the front, at either side). If it is the early type, there's 2 really obvious screws to take out.
Then there's a couple of bolts on extensions below the bottom corners of the back; undo them & then it'll just lift out vertically; there are 2 hooks that secure it.
Easy job :thumb:
Posted: Wed Apr 20, 2005 6:04 pm
by Project_E30
Cheers will have a go on Friday. Its an 89 F plate by the way
Posted: Wed Apr 20, 2005 6:23 pm
by Simon13
Then just pull the bench up, the upper part has 2 small 10mm bolts securing it. Remove these and lift up and your in business!
Posted: Wed Apr 20, 2005 10:20 pm
by Andy_magic
Don't rip your rear trim panels, be careful when removing the seat back as the metal bits can rip the bottom of the trim panels.
Posted: Thu Apr 21, 2005 8:05 am
by Project_E30
Thank you all very much!
Posted: Thu Apr 21, 2005 8:08 am
by E30Mark
The bolts holding the seat back are hidden away just behind the bottom corner of the side trim panel... you'll see what i mean when you pull it apart.
Re:
Posted: Sat Jul 26, 2008 4:29 pm
by davemi16
Thanks for the replies to the thread, i have just found this info useful :clap:
