HEAD FLOW
daveo
Wed May 30, 2007 1:51 pm
How well dose a m20 cylinder head flow if i was to get the head ported and poslished how much of a power increase would i see.
tia
dave
maxfield
Wed May 30, 2007 1:58 pm
Depends what other mods you do also.
Cam?
BBTB or ITBs?
6 Branch?
All these would help increase power with porting and polishing.
ed325i
Wed May 30, 2007 2:03 pm
Bigger valves ?
daveo
Wed May 30, 2007 2:18 pm
im going to using a mild cam with a 6 branch manifold.
ed325i
Wed May 30, 2007 4:06 pm
It still depends on who and how the head is ported.
2 to 4 bhp extra I would think on its own.
daveo
Wed May 30, 2007 4:43 pm
so what you are going to gain over standard its not really worth it.
davecave
Wed May 30, 2007 4:47 pm
Will you really gain anything for all the work it will take mate????
maxfield
Wed May 30, 2007 4:50 pm
davecave wrote:Will you really gain anything for all the work it will take mate????
Depends how much power he's aiming for.
If with BBTB, 6 branch and a decent cam then it will probably make a significant difference.
ed325i
Wed May 30, 2007 5:01 pm
Who is going to port the head ?
You need a flow bench to make sure each port is flowing the same.
I wouldnt polish the inlet side but go for nice polished exhaust ports.
e21Jason
Wed May 30, 2007 5:11 pm
Hi
The 885 head flows pretty well from the box about 20% over the small port head. The real only gain is to run bigger valves and bigger throats, but the m52 heads flow about 30% more than a 885 another reason for an engine swap.
My mate is runing a load of tests on m20 heads on his flowbench at work so i hope to have real data soon.
The intake system is going to give more restance than the head, MS is probably going to gain more than head work.
Jason
ed325i
Wed May 30, 2007 7:16 pm
Could an inlet manifold be made that flows better ?
What would be the best design ?
Turbo-Brown
Boost Junkie
Wed May 30, 2007 8:25 pm
Throttle bodies should flow better than the cast inlet :)
reggid
Thu May 31, 2007 3:26 am
i am looking into doing a extrude hone + gasket match and clean up aroung the ports on my intake manifold in the coming months and i have heard 20% flow increases but thats definately not a 20% power increases. Its an expensive exercise (~250 pounds) but i'll be doing before and after dyno runs for all to see.
Turbo-Brown
Boost Junkie
Thu May 31, 2007 8:12 am
Would be cool if you can do that in isolation without any other mods reggid :D
reggid
Thu May 31, 2007 9:51 am
Turbo-Brown wrote:Would be cool if you can do that in isolation without any other mods reggid :D
thats the plan but it may take a few months for things to happen
Turbo-Brown
Boost Junkie
Thu May 31, 2007 1:31 pm
Good things to those who wait :D
e21Jason
Thu May 31, 2007 1:45 pm
Hi
With out going to ITB's a log style manfold with a big throttle body would flow better something like this.
http://sdsefi.com/techinta.htm
The GT power simulation for the m20 shows up a decent pressure drop across the standard manifold
http://www.gtisoft.com/broch_gtpower.html
Check out the US fourms like rev3 or e30tech for the opinons on the extrude hone.
Ditch the AFM and go to alpha-n will give the best result for least spanner work. That's why it is very popular on s14's, even better if you go to stand alone.
Jason
ed325i
Thu May 31, 2007 4:48 pm
Thats more like it.
ed325i
Thu May 31, 2007 7:49 pm
I have been looking at building ITB's using suzuki gsxr 600 T/B's like the bloke on e30tech.
Turbo-Brown
Boost Junkie
Thu May 31, 2007 10:11 pm
Just make sure you don't point No.6 cylinder's intake straight at the servo like whoever made that has done!
