knocking noise from rear of car
Posted: Sat May 26, 2007 8:07 pm
by raj
hiya I own a 325i cab and need some help when driving I can hear a knocking noise from the rear of the car (driver's side) any idea's what it could be thanks
Re: knocking noise from rear of car
Posted: Sat May 26, 2007 8:12 pm
by Nelly
Rear subframe bushes need changing, rear top mount shagged, prop center bearing knackered??
Posted: Sat May 26, 2007 8:13 pm
by Falkster
Easy one to eliminate is to drive down the road with your handbrake on one notch!! Could be the hand brake not been tight enough on that side....it rattles within the rear disc
Posted: Sat May 26, 2007 8:23 pm
by Chris-W
As Nelly says, but my bet would be a rear top mount.
Posted: Sat May 26, 2007 8:39 pm
by raj
thanks guys are they hard jobs to do and how can I test to see if it is those parts
Posted: Sat May 26, 2007 8:56 pm
by Nelly
Rear top mount - lift the rear part of the roof + open the horseshoe section - in there on the drivers side you'll see a black plastic rectangle - pop this up to reveal the top mount, ten to the penny you'll see tiny shards of rubber.
Also whilst looking at it, bounce the rear of the car slightly to see the movement in it.
Prop center bearing - doubt it is this but, remove the heat shields and grab hold of the prop in the middle - shake to see if there's any up/down/side to side excess movement.
Subframe bush - by jacking the car slightly under the diff, you'll be able to see the rear beam move/slide up the ally center of the bush.
Posted: Sat May 26, 2007 9:03 pm
by raj
thanks mate how much are top mounts and what's the best place to get them is ittrue that you can fit m3 ones
Posted: Sat May 26, 2007 9:05 pm
by Nelly
Yep - get the E46 M3 rear top mounts iirc, their about £9 each from BMW
Posted: Sat May 26, 2007 9:32 pm
by raj
any chance for a part number thanks alot
Posted: Sat May 26, 2007 9:37 pm
by Brianmoooore
33 52 6 754 096. Best replaced in pairs.
Posted: Sat May 26, 2007 10:23 pm
by raj
thanks alot guys will be done on tuesday
Posted: Sat May 26, 2007 10:47 pm
by Brianmoooore
Do it the easy way by removing the damper complete with the top mount, and fitting the new top mount onto the damper before replacing them together.
Don't fully tighten the bottom damper bolt until the rear of the car is at normal ride height again sitting on its wheels.
