heater matrix
Posted: Fri May 18, 2007 8:24 pm
by Shinobi1
Hi ,anyone replaced a heater matrix insitu before ? just replaced the valve that was leaking , now i think the matrix is leaking too :cry: :cry:
cheers paul.
Re: heater matrix
Posted: Fri May 18, 2007 8:26 pm
by Chris-W
It can be done, but for the extra work involved, dash out is sooo much easier.
Posted: Fri May 18, 2007 8:27 pm
by StuBeeDoo
Re:
Posted: Fri May 18, 2007 8:57 pm
by DanThe
Did you get yours sorted essbee?
Re: heater matrix
Posted: Fri May 18, 2007 9:21 pm
by Shinobi1
Chris-W wrote:It can be done, but for the extra work involved, dash out is sooo much easier.
i have only just put the dash in !!!
Re:
Posted: Fri May 18, 2007 9:48 pm
by StuBeeDoo
DanThe wrote:Did you get yours sorted essbee?
Sort of Dan, sort of.....
I put a packet of Ce-lit in and dried the carpet. It's all good at the moment but I'm keeping an eye on it. TBH, I'm not sure if it's the matrix or the valve that's at fault.
Posted: Fri May 18, 2007 10:40 pm
by Giggz
I recently had a leak in the passenger footwell and found that one of the rubber pipes that are attached to the matrix pipes coming from the bulk head were not tight enough. I tightened the jubilee clip and the leak has stopped but i still aint got no heat coming from the vents! :cry:
HTH.
Posted: Sat May 19, 2007 9:27 am
by Shinobi1
Giggz wrote:I recently had a leak in the passenger footwell and found that one of the rubber pipes that are attached to the matrix pipes coming from the bulk head were not tight enough. I tightened the jubilee clip and the leak has stopped but i still aint got no heat coming from the vents! :cry:
HTH.
i have just fixed the valve and it looked like water was coming from the housing below but then then seemed to stop so going to have another look today :)
cheers paul.
