Power windows trouble
Posted: Sat Apr 28, 2007 11:56 am
by HarvyS
Hello,
Im having a bit of trouble with my power windows in my 318is, When i have the doors closed the windows will not go up or down but when i have 1 of the doors open both windows operate perfectly. Any suggestions on whats wrong with them? Any help would be much appreciated! Thank you!
Harvy
Posted: Sat Apr 28, 2007 12:19 pm
by smithy318i
check fuses
17 and ? are for electric windows.
Re:
Posted: Sat Apr 28, 2007 12:27 pm
by HarvyS
Wow! I love this forum, that was a quick reply thanks smithy. Will try it when i get home!
Re:
Posted: Sat Apr 28, 2007 12:32 pm
by dimebag_from_hell
I hit a big bump on the road recently, with the low profile tyres and 17 inch alpina's, a big shock went through the car! Now i cant open or close the passanger side window :evil:
Re:
Posted: Sat Apr 28, 2007 12:53 pm
by HarvyS
Ouch! Have you had a look at the connections and mechanism for the window the bump might have knocked something out or loose? Ive tried the fuses with no luck. I suspect its those electrical door pins that tell the power windows when the doors are closed. Is there any way to test them? sorry i don't know the name of them.
Re:
Posted: Sat Apr 28, 2007 2:14 pm
by Brianmoooore
Teach you to run silly wheels and tyres!
If it's only one side affected, then it's likely to be the switch or the door hinge pillar plug and socket. Nothing to do with door pins or fuses.
