Leaking Shock Absorber
Posted: Thu Apr 19, 2007 3:10 pm
by Wookie
I noticed about 6 months ago that my rear left shock absorber was leaking, so I decided to replace it. Once it was in, all was well. I noticed again at the weekend while I was doing some work on the brakes, that this shock absorber is now leaking as well. What causes shock absorbers to leak?
Re: Leaking Shock Absorber
Posted: Thu Apr 19, 2007 4:41 pm
by cliffybabe
is it the right shock for ur car??
whats ur car spec engine etc, have u lowered it, what wheels u running etc
Posted: Thu Apr 19, 2007 6:55 pm
by kam-325i
If the travel of the shock absorber is not true/parrallel, it will cause the seals to fail.
Posted: Fri Apr 20, 2007 7:19 am
by Wookie
cliffybabe wrote:is it the right shock for ur car??
Yes, it is the correct one. It's exactly the same as the one on the right side. Car is a 318i, standard suspension setup, with 195/50 15 inches. Other than that, all is standard...
Posted: Fri Apr 20, 2007 7:14 pm
by irish-e30
by true running do you mean tracking??? could be right there!!
Posted: Fri Apr 20, 2007 7:20 pm
by kam-325i
irish-e30 wrote:by true running do you mean tracking??? could be right there!!
No, not the tracking. i mean the path the shock travels through, or more to the point, has the bottom shock mounting point had any damage, causing it to be out of line.
Posted: Sat Apr 21, 2007 9:18 am
by Wookie
No damage since I've owned the car. Can it not be attributed to worn top shock mounts or other worn suspension bushings?
