early high comp engines
Posted: Thu Apr 05, 2007 9:09 pm
by slippo
is there any way to tell apart the low/high comp engines? mines a 88 e reg chromp bumper cab so i think that right on the change over, is ther any numbers or ne thing?
Re: early high comp engines
Posted: Thu Apr 05, 2007 10:59 pm
by Ziggy
Um... easiest way's probably to look at the ECU - if the number ends in 073 it's on early (1.1?) Motronic, 173 is late (1.3?). They swapped at the same time as the high / low comp lumps... I expect you can tell from engine numbers too, but I don't know how exactly!
Posted: Fri Apr 06, 2007 12:33 pm
by tomson
checking the ecu numbers isnt conclusive.
Ive had open at least 2 motronic managed m20's that have the early high compression pistons in them and ive spoken to others that have found the same thing.
I would think the way to tell without removing the head would be to measure the compression perhaps???
HTH
Posted: Fri Apr 06, 2007 12:58 pm
by reggid
engine code which is near to the engine number on the side of the block
25 6k 1 = low comp
25 6e 1 = high comp
Posted: Fri Apr 06, 2007 6:45 pm
by slippo
cool cheers will have a look
Posted: Fri Apr 06, 2007 7:50 pm
by maggspower
have a look at the plug that the reset tool goes into, its by the inlet manifold towards the front end of the car, the pre face lift one is small and D shaped face lift one is larged and round :) that way you can tell at a glance. hope this helps.
Posted: Fri Apr 06, 2007 7:53 pm
by maggspower
what i ment was D shaped is high comp :mad:
Posted: Mon Apr 09, 2007 5:40 pm
by tomson
maggspower wrote:what i ment was D shaped is high comp :mad:
as per my earlier post thats not always the case........
