Multifit 18 inch rims
Posted: Tue Apr 12, 2005 7:44 pm
by popupstands
Just about to order some multifit rims 18inch 18x8 et40
I have flared out arches but need to know if these will fit ?
Posted: Tue Apr 12, 2005 7:54 pm
by johnono
e30 adam has just had it done on his
although it would depend on tyre width and how low the car runs
Posted: Wed Apr 13, 2005 12:59 pm
by motorsport
Are they Alpina reps by any chance.
Thinking of getting some this size too, apparantly only the rears need modding unless running a stiff setup.
Will check it out though first.
The tyres quoted were 215/35/18, only 1mm greater diameter than a 15" BBS with 205/55/15 fitted, and 3mm less than 17"with 215/40/17 fitted.
Will have to see if a wider tyre than 215 is required.
Andy
Posted: Wed Apr 13, 2005 10:50 pm
by popupstands
no I have got 17 inch Alpina reps but now going for a 18 inch old skool style
Posted: Wed Apr 13, 2005 11:13 pm
by E30Adam
johnono wrote:e30 adam has just had it done on his
No I haven't, mine are 16's. I'd never wreck my car by putting hideous 18" wheels on it.
Back to the question in hand... shouldn't you have checked this before doing anything to your arches. How did you flare them, you can't flare a stock arch.
Posted: Wed Apr 13, 2005 11:23 pm
by Simon13
Adam you have modified your arches for those keskin rudeness, some might think thats naughty also!
Player 6 has 19's on and i don't think he had to do alot of arch work, but again i don't know the offset of his rims.
Andyboy (think thats his name! Green 318i design cab)
Has 18inch Kahns on his which look sweet and his arches look standard. Also at a guess it's dropped 40mm too.
HTH
