non starter (electrical)
Posted: Sat Mar 31, 2007 4:06 pm
by DawsiRn
hi, just performed an engine swap on my 318is went to start him up but got bugger all, no lights, no noises juist a whole lot of nothing!
tried a battery which i know has charge and that didnt work.
my hunch is its a missing earth somewhere but the only ones i can think of are the one on the driversside nr. the engine mount and the one linking the alternator to the engine. and ofcourse the one linking the battery to the suspension mount. Is there another one on the passenger side because i'm having problems remembering.
performed a continuity tests on the ones i mentioned above and all seems ok.
i'm hoping i've connected everything else back up ok.
so thought i'd ask you lot. could it be an earth or something else entirely??
any help would be very much appreaciated!
cheers.
Re: non starter (electrical)
Posted: Sat Mar 31, 2007 4:11 pm
by jamesh1977
you tried using a jump lead straight off the earth of the battery to the engine to see if you get anything that way ?
also double check all the positive conections also make sure all the plugs ectra are connected along the side of the bulk head
Posted: Sat Mar 31, 2007 5:36 pm
by eko
Ok im no expert but you say you have no ignition/oil light coming on?
You should have 2 small leads bolted to the battery+ main lead,1 for the engine loom and 1 for the fusebox.
Are both of these connected?
Posted: Sat Mar 31, 2007 7:21 pm
by DawsiRn
jamesh1977 wrote:you tried using a jump lead straight off the earth of the battery to the engine to see if you get anything that way ?
Yeh just tried this and still getting nothin. i'll av a look at all my positive connections tommorow.
yeh these are both connected.
i'm hoping i've got all the connections right, but i'm a little unsure about one plug i found...its apart of the main loom which basically reaches as far as the ecu, i found a little place for it to slide onto (directly ontop of the ecu housing) but i cant find any male plug to fit into it. I know i shoulda taken better care and made some better notes when i was taking it apart but ohwell whats done is done :o:
if anyones got any idea what that is then i could rule that out.
keep the suggestions coming please :)
Posted: Sat Mar 31, 2007 7:23 pm
by jamesh1977
where are you based mate ? maybe a local zoner could pop in and give you a second idea
Posted: Sat Mar 31, 2007 7:42 pm
by DawsiRn
I'm in bristol mate, but i'll spend i a load of time having a look tommorow so i shouldnt have to waste anyone elses time. i am an (domestic) electricain by trade so i should be able to figure it out in the end....hopefully!
Posted: Sat Mar 31, 2007 10:33 pm
by Brianmoooore
If the three wires are on the battery + terminal, then it sounds like the battery neg isn't being earthed.
If you look in the top of the fusebox, you will see a hex headed bolt in a recessed hole. This bolt is the main 12V feed to the fusebox from one of the smaller two wires on the battery +. Check that 12volts is present at this bolt.
I shouldn't have to warn you about false readings from voltmeters on unloaded circuits.
Posted: Sun Apr 01, 2007 11:18 am
by DawsiRn
Brianmoooore wrote:If the three wires are on the battery + terminal, then it sounds like the battery neg isn't being earthed.
alright mate, couldnt find the bolt your describing. i would take a picture but i dropped my camera the other day and buggered it so cant do that!
is there any other positive terminals that i can get a reading from? to be honest i dont even know where to begin with car electrics, (and i'm far to hungover today to even try and figure it out :(
the annoying thing is its probably something real simple.
Posted: Sun Apr 01, 2007 11:36 am
by Brianmoooore
Pin 14 is 12V+ in the diagnostic connector. Short it to pin 11, and the starter motor should engage.
