Check Control
Posted: Tue Mar 27, 2007 9:36 am
by parksie
Can someone please offer some advice :)
The Check Control panel is showing a brake light warning although the brake lights are fine.
How can i stop this little shit of a light coming on,or has something gone past it's sell by date?
Any tips much appreachiated guys.
Re: Check Control
Posted: Tue Mar 27, 2007 9:40 am
by fowler
check the resistance on the back lights as this will be the problem it coould be a s simple as a corroded pin .
Simple description
when lamp blow resistance goes sky high tell computer its broke get my drift!!!
if the resistance is high enough to simulate a a busted light it will tell you so easy way to check is to take the tail lights out and just have a general look around.
Because ALL E30's get condensation in the boot.
Re: Check Control
Posted: Tue Mar 27, 2007 10:36 am
by parksie
Ok , tried all of the above,even changed the back panels that hold the bulbs with a spare set to no avail :? also changed the brake light bulbs :!:
so I'm now looking at the Check control panel :!:
Re: Check Control
Posted: Tue Mar 27, 2007 8:04 pm
by parksie
Well bugger me :!:
After following fowlers tips nowt different happend,prior to parking the car up tonight NO check control light :D
The wonders of WD40 8O
Re: Check Control
Posted: Tue Mar 27, 2007 10:02 pm
by oze30
That and a little tap on the suspect lights usually works a treat!
Re: Check Control
Posted: Tue Mar 27, 2007 10:08 pm
by Brianmoooore
You realise that it only takes a brake light malfunction for a fraction of a second to put the LED on, and for it to stay on until the ignition is turned off?
Problem can also be caused by a faulty or maladjusted brake light switch.
