Valence different on Air-Con cars?
Posted: Sun Mar 18, 2007 10:04 pm
by suzie650
Hi
Sorry, I have a quick question again. Is there an E30 that has a second cut-out in the metal valence to accomodate the upper opening on a Tech II front valence? Cars with factory-fitted A/C?
And in that case, is it advisable to "open" my valence when I come to retrofit the A/C?
Séb
Re: Valence different on Air-Con cars?
Posted: Sun Mar 18, 2007 10:11 pm
by FESI
yes it is different it has two horizontal holes for air con models, well i would advise you to open it but it is not essential
Posted: Sun Mar 18, 2007 10:18 pm
by suzie650
Posted: Sun Mar 18, 2007 10:24 pm
by ian332isport
I've not opened mine up, and it seems to work fine.
Ian.
Posted: Sun Mar 18, 2007 10:33 pm
by suzie650
But your Kit was factory fitted, wasn't it? What is used to hide the metal valence then?
Posted: Sun Mar 18, 2007 10:37 pm
by ian332isport
suzie650 wrote:But your Kit was factory fitted, wasn't it? What is used to hide the metal valence then?
I fitted mine myself (the aircon, the body kit was factory) 8)
On a standard sport, there's just a strip of black tape on the valance to make the hole in the tech2 valance look dark.
Ian.
Posted: Sun Mar 18, 2007 10:53 pm
by suzie650
ian332isport wrote: I fitted mine myself (the aircon, the body kit was factory) 8)
Lucky man! Our cars have unfortunately some "history"... Try to line up the *&?!!$@ togther...
OK, seen it on the ETK. Didn't you have any issues with not having airflow onto the condenser?
Posted: Mon Mar 19, 2007 8:15 am
by mrLEE30
the factory fitted A/C condensor radiator pulls air from the grill/kidney area aided by an electric fan, the upper hole in the lower valance is normally for the oil cooler unit used on most (if not all 325's) and some (round these parts) 320's, although i dont belive they do so much.
you can see below the factory condenser almost hidden behind the electric fan, the lower valance will not flow too much air to this area ,if any at all (ignore the circled bits that for the tech 2 tech article)
Re:
Posted: Mon Mar 19, 2007 8:37 am
by beardymat
although not essential, BMW put the hole there for some reason and since its not difficult to cut it would probably be better to cut it out if you can as more airflow can only be a good thing.
mind you i am lucky enough to have the correct valance so its probably just the snob coming out.lol
Posted: Mon Mar 19, 2007 9:08 am
by ian332isport
mrLEE30 wrote:the upper hole in the lower valance is normally for the oil cooler unit used on most (if not all 325's) and some (round these parts) 320's, although i dont belive they do so much.
The oil cooler uses the lower hole in the lower valance. The upper hole is for the aircon.
Ian.
