Fuel pump help needed!!
Posted: Mon Mar 05, 2007 6:46 pm
by tomm
My fuel pump had been sticking on startup, so this evening I swapped it for a replacement purchased from a bloke on here.
The car won't start.
I've checked the power lead: the pump power cable provides good voltage on turning the engine over. I've removed the fuel pipe and cranked the engine over, and no fuel comes out at all.
Am I missing something, or have I replaced a dodgy pump with a totally knackered pump?
Re: Fuel pump help needed!!
Posted: Mon Mar 05, 2007 7:36 pm
by johnna
Hi Tomm,
the pump was working well.
Are you getting a good Earth too? Try testing the other terminal in the loom for continuity. (Beep function on Multimeter).
Test the pump using two wires directly to the battery. If it won't work, remove it and I'll refund you mate. I'm not into ripping peeps off.
Bugger!
Posted: Mon Mar 05, 2007 7:41 pm
by tomm
Hi John
Don't worry - that's not what I was getting at
It's just a ball-ache as I need to get to work in the morning!
I'll go and test the pump in a mo...
Posted: Mon Mar 05, 2007 8:33 pm
by tomm
Earth was good. Not a peep from the new pump on testing
whereas mine intermittantly squirted petrol at the missus
I wonder if it's got an internal problem, as there's absolutely no resistance between its terminals?
Posted: Mon Mar 05, 2007 10:17 pm
by old_skool
Thump it! It's likely just stuck. That normally gets them going again.
Posted: Mon Mar 05, 2007 10:22 pm
by SPADGE
old_skool_2002 wrote:Thump it! It's likely just stuck. That normally gets them going again.
Kick it in the gonads if thumping it doesn't do the trick
Posted: Mon Mar 05, 2007 10:24 pm
by johnna
Refund made
Posted: Mon Mar 05, 2007 10:50 pm
by Brianmoooore
I've found this before. Perfectly good fuel pumps that refuse to work when rehoused in another car!
Must be something to do with a surface layer of corrosion forming inside the pump when it dries out.
I've taken to running some light oil up inside pumps when I take them out to store them, and haven't had the problem since - but that may just be coincidence.
Posted: Mon Mar 05, 2007 10:57 pm
by johnna
I'd go for that...
Posted: Wed Mar 07, 2007 9:21 pm
by tomm
It's a bugger. Someone on another board got three E30 pumps from a scrappy, and only one worked - it may well be a 'feature' of these pumps. If I try and get one from a scrappy, I'll have to take the battery with me to test it!
Alternatively, someone suggested trying to stick any other brand's cheap pump in there instead, but I'm having trouble finding anything small enough! Any suggestions?
Posted: Wed Mar 07, 2007 9:32 pm
by SPADGE
Tomm
I have a pump here that only yesterday i removed from an E30
The car was running yesterday so it hasn't been standing 'dry' for any time really.
Its from a 90 318i i don't know what car you have?
Posted: Wed Mar 07, 2007 9:35 pm
by tomm
It's a 320i with an in-tank single outlet pump. I'm not sure if they're compatible?
Posted: Wed Mar 07, 2007 9:36 pm
by fuzzy
SPADGE wrote:Its from a 90 318i i don't know what car you have?
i might be mistaken but i was told all 'i' e30's use the same pump.
Posted: Wed Mar 07, 2007 9:42 pm
by SPADGE
Not sure either to be honest although i see from your wanted ad your after one with one outlet and mine has 2.
I have a 320i touring here that i could sell you the pump off but it would mean making it immobile so i would need a decent offer
Posted: Wed Mar 07, 2007 9:47 pm
by Brianmoooore
fuzzy wrote:SPADGE wrote:Its from a 90 318i i don't know what car you have?
they do, but there are two different mounting brackets.
Posted: Wed Mar 07, 2007 9:50 pm
by Brianmoooore
SPADGE wrote:Not sure either to be honest although i see from your wanted ad your after one with one outlet and mine has 2.
You can use a two outlet pump (actually one is an inlet) in place of a single outlet pump, but the spare pipe will need to be blanked off. Easiest way is with a short length of fuel hose, two clips, and a short piece of steel rod shoved up the end.
Posted: Wed Mar 07, 2007 10:06 pm
by SPADGE
Brianmoooore wrote:SPADGE wrote:Not sure either to be honest although i see from your wanted ad your after one with one outlet and mine has 2.
Cheers Brian keep the knowledge coming i'm soaking it all up like a sponge
There you go then Tomm either way i have a pump for you
Posted: Thu Mar 08, 2007 10:30 am
by tomm
Thanks Spadge.
You have PM...
