Brake light wont go off
Posted: Wed Feb 21, 2007 7:24 pm
by sam325is
my brake lights on the clusters wont go off.
when the brake pedal is pushed they just blink and stay on.
any ideas?
Re: Brake light wont go off
Posted: Wed Feb 21, 2007 7:30 pm
by dobbie82
there is a little switch behind the brake pedal easy to take out, perhaps its sticking on?
Posted: Wed Feb 21, 2007 7:38 pm
by Cotty
dobbie82 wrote:there is a little switch behind the brake pedal easy to take out, perhaps its sticking on?
Thats what I thought, I had the same problem. Changed mine recently £9 for the switch from the dealers
Posted: Wed Feb 21, 2007 9:04 pm
by Brianmoooore
It won't switch off if the brake pedal isn't coming up far enough to work it. In this case the pull rod that goes across the car behind the heater box will need adjusting slightly.
Posted: Wed Feb 21, 2007 9:09 pm
by tylerma
sam325is wrote:my brake lights on the clusters wont go off.
any ideas?
when you say clusters do you mean the instrument cluster
on the dashboard
if so it might be your brake sensor
you have 2 nearside front and offside rear
so your pads could be due a change
Posted: Wed Feb 21, 2007 11:55 pm
by sam325is
no i mean the rear lights. it just suddenly started happening. i will have to investigate tommorow, thanks
Posted: Wed Feb 21, 2007 11:59 pm
by m3mpower
i'm sure its something to do with the brake light switch which is located behind the brake pedal.
Posted: Thu Feb 22, 2007 8:10 am
by ajay31
the brake switch usually sticks, remove from top of pedal and push it into housing gently it will click when back at right position.
Posted: Thu Feb 22, 2007 11:38 am
by sam325is
i just went outside and pulled the connection plug out and blew on it, then pushed the switch(didnt hear a clcik though) and now its all fine.
thanks for the help guys/girls
