M20 in engine stand pictures wanted
Posted: Thu Feb 15, 2007 11:46 am
by wildeian
Anyone got any pics of this?
Can't figure out how to mount the engine in the stand at the moment :mad:
Do i need to take the flywheel off?
Posted: Thu Feb 15, 2007 1:21 pm
by charlE30
I haven't got a photo but when I used mine last I removed the flywheel and bolted it to four opposing gearbox mounting holes using some burly (correct thread) bolts.
It didn't feel very safe though, four bolts suspending all that weight :eek:
Charlie
Re:
Posted: Thu Feb 15, 2007 1:26 pm
by Quaser
i built an engine in the same way - seemed to be ok for the month that it was on!
Re:
Posted: Thu Feb 15, 2007 11:50 pm
by DanThe
The way Charlie says is the proper way but it will give you problems if your engine is timed up by locking the flywheel, like the M50 I have on my stand at the mo :roll:
I have seen engines bolted to the stand sideways, I didnt fancy it with mine as most the threaded holes are only 8 mm
Re:
Posted: Fri Feb 16, 2007 6:09 pm
by wildeian
How about ANY engine in a similar stand?? :roll:
Re:
Posted: Fri Feb 16, 2007 7:04 pm
by DanThe
Best one ive got
Re:
Posted: Fri Feb 16, 2007 7:07 pm
by Simon13
what a gay engine! or is it a 2.8 proper one?
Re:
Posted: Fri Feb 16, 2007 7:13 pm
by DanThe
I agree completely Simon :)
It was only on the stand to make removing the crank,rods and pistons easier, why elso do you think it would be on there? :)
Oh and the head, they fetch good money winkeye
Re:
Posted: Fri Feb 16, 2007 9:10 pm
by baxter
wildeian wrote:How about ANY engine in a similar stand?? :roll:
this is the only one i have but its going to be worthless to you
Re:
Posted: Fri Feb 16, 2007 10:56 pm
by DanThe
because we cant see it?
Re:
Posted: Fri Feb 16, 2007 11:02 pm
by Brianmoooore
I've got a set of very long bolts + three nuts for each (one each side of the engine stand tube, and one against the engine), which allow the engine to be bolted on with flywheel in place.
More stable if it's bolted right up to the stand without the flywheel.
Re:
Posted: Fri Feb 16, 2007 11:15 pm
by wildeian
Cheers Guys, it's all helping. Keep 'em coming if you have anymore :D
Re:
Posted: Fri Feb 16, 2007 11:22 pm
by SPADGE
A not too good one of my M30 with the Draper stand struggling under its weight!
I always remove the flywheels
A few of Cossies i have done
Re:
Posted: Fri Feb 16, 2007 11:24 pm
by wildeian
Cheers Spadge, thats exactly what I needed!! :D
