FOGS DONT WORK!!!!!!!!!
Posted: Mon Feb 12, 2007 2:16 pm
by E3OSAM
Hi as u have read, my front fogs dont seem to work. i changed the bulbs and they worked for a bit if i hit them but know they wont come on at all, the fuses are fine just wondering if any one had any thoughts.
Re: FOGS DONT WORK!!!!!!!!!
Posted: Mon Feb 12, 2007 2:18 pm
by dobbie82
do you have a multimeter so you can check continuity? could be a break along the wire somewhere?
Posted: Mon Feb 12, 2007 6:04 pm
by sam325is
could be rusty wires where they go in to the connector plugs that go into the back of the lamps.
Posted: Mon Feb 12, 2007 6:10 pm
by GBE30
Try changing the switch, pennies on ebay and they sorted mine out when they stopped.
Posted: Mon Feb 12, 2007 11:22 pm
by E3OSAM
cheers for the advice i will hopefully try that lot 2moz
Re:
Posted: Tue Feb 13, 2007 2:13 pm
by nickso
take the switch apart...they go really green inside for some reason.
Re:
Posted: Tue Feb 13, 2007 7:26 pm
by Brianmoooore
More random part swapping advice instead of testing! Cure one fault - cause five more!!!!
Does the fog light warning lamp in the instrument cluster light? If not, pull out the fog light relay, K8, and connect a piece of wire between battery + and pin 87 of the relay's socket. Do the foglights work with this in place? Does the warning lamp light up now?
Turn the foglights on. Does relay K8 click as you pull it out and push it back in?
Re:
Posted: Tue Feb 13, 2007 10:42 pm
by wildeian
It's called 'verdigris'
Verdigris is the common name for the chemical Cu(CH 3 COO) 2 , or copper(II) acetate. It commonly occurs by the action of acetic acid when copper, brass or bronze is weathered and exposed to air or seawater over a period of time. 8O
Had it in mine too, opened switch, cleaned it out and all worked fine! :wink:
