e30 325i with 3.91 diff
fannyj
Wed Feb 07, 2007 10:07 am
Hi Guys
I have a 3.91 diff in the garage and have been contemplating fitting it this weekend. My car is stock standard and drive about 100km to work and back. Would this diff cause the revs to run ridiculously high while cruising on the highway? Currently at about 120kph in 5th, i'm doing round 3000+/- rpm
Ziggy
Wed Feb 07, 2007 10:15 am
They won't be ridiculously high, but they will be higher (assuming you've got a 3.64 at the mo? Can't be bothered to work it out from your figs!). I've got a 3.91 in mine (& they were standard on the facelift 325i sports) & it's fine, but you'll probably notice the extra fuel you'll be using... Can't say I'd really recommend it if you spend a lot of time at high speeds!
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Feb 07, 2007 10:52 am
ive og t a 3:91 dif on my cab and im well pleased with it winkeye
snoops
Major Helmet
Wed Feb 07, 2007 10:53 am
id say keep the 3.64 on there if you do cruising at high speeds but if its acceleration your after then fit it
Ziggy
Wed Feb 07, 2007 10:54 am
cliffybabe wrote:ive og t a 3:91 dif on my cab and im well pleased with it winkeye
So am I! :)
But if I had a 60 mile drive to work on the motorway every day, I'd stick a 3.64 back on...
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Feb 07, 2007 10:55 am
So am I! :)
thank god mine only a weekend car :cool:
GDBN
Wed Feb 07, 2007 10:59 am
Weekend car - which you spend in the boot ...
I deserve 6 of the best ...
Ziggy
Wed Feb 07, 2007 11:03 am
GDBN wrote:Weekend car - which you spend in the boot ...
:lol:
fannyj
Wed Feb 07, 2007 11:23 am
thanks for the replies guys..guess i will be sticking to the 3.64.
spence_star
Wed Feb 07, 2007 11:25 am
whats the difference in ratios with an open diff?
Returned after many years out.
fannyj
Wed Feb 07, 2007 11:33 am
Ziggy
Wed Feb 07, 2007 11:37 am
spence_star wrote:whats the difference in ratios with an open diff?
Don't understand the question really... :? You can get most of the same ratios in open & LSD form, if that's what you mean?
spence_star
Wed Feb 07, 2007 11:43 am
ok, because i got an open diff, and all i know is it dont save you if you lose the back end. i am not sure what ratio i am running.
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Feb 07, 2007 11:46 am
very good
It keeps tent costs down winkeye
GDBN
Wed Feb 07, 2007 11:55 am
You should install a coffee machine in the boot so next time you can have a coffee while waiting for help.
Ziggy
Wed Feb 07, 2007 12:01 pm
spence_star wrote:ok, because i got an open diff, and all i know is it dont save you if you lose the back end. i am not sure what ratio i am running.
Ok... well nor will a LSD, but anyway... what's the question?
If you want to know what diff you've got, have a look at the tab on it, or at least tell us what car you've got! :)
Ziggy
Wed Feb 07, 2007 12:02 pm
GDBN wrote:You should install a coffee machine in the boot so next time you can have a coffee while waiting for help.
Ah, so there is some point to all the cr@p they fit on Pimp My Ride - you should apply Cliffy!
cliffybabe
Powered by Nelly
Powered by Nelly
Wed Feb 07, 2007 12:04 pm
:lol: y all they'd do is fit chrome archs and some brown interior im alreayd half way there :lol:
