electric window and sunroof problem m3
Posted: Tue Jan 30, 2007 9:27 am
by tobias
hi guys all of a sudden both have stopped working not sure why.....and yes i have checked the fuse its fine
thanks in advance toby
Re: electric window and sunroof problem m3
Posted: Tue Jan 30, 2007 4:50 pm
by tobias
any ideas fellas???
Posted: Tue Jan 30, 2007 6:26 pm
by tobias
is there some sort of relay which controls them al which may have gone?????
sorry im crap with electics lol
Posted: Wed Jan 31, 2007 12:42 am
by MONSPORT42
Do they work with a door open, i.e. is it just the switches. If they are working with the doors open then it's likely to be an earthing problem. Happened for a while on my Sport especially in the wet. A member suggested cleaning/tightening the cables on the starter motor connection (disconnect battery first). They've worked perfectly ever since. Might help.
Posted: Wed Jan 31, 2007 12:53 am
by eko
You are aware that there are 2 seperate fuses for the windows?
One for doors closed,one for doors open!
Posted: Wed Jan 31, 2007 8:42 am
by jpboost
there are 2 relays that control the electric windows.
they use 1 relay in normal use (ignition on) , and the other one when the doors are open & ignition is off.
so if they work when the ignition is off/door is open then you know it's the other relay.
pick a relay that you know is good (i.e. something like the horn one is easy to check) and swap em over. then you'll know for sure.
Posted: Wed Jan 31, 2007 6:09 pm
by tobias
your right boys!!! they work with doors open. which relay/ fuse needs switching???
thanks again for all the help
toby
Posted: Wed Jan 31, 2007 10:44 pm
by tobias
what numberfuse for ignition on
Posted: Wed Jan 31, 2007 10:49 pm
by eko
this will come in handy for you i think!
http://www.e30zone.net/modules.php?name ... 0fuses.htm
Posted: Wed Jan 31, 2007 11:03 pm
by tobias
hi eko electric windows on this table..... any ideas
Posted: Wed Jan 31, 2007 11:33 pm
by tobias
sorry i meant it doesnt say which one for leccy windows
Posted: Wed Jan 31, 2007 11:47 pm
by Brianmoooore
Fuse 17 is for the windows/roof with the ignition on. Fuse 28 is for the windows/roof with the doors open, ignition on or off. Both 30A.
Posted: Wed Jan 31, 2007 11:50 pm
by tobias
cheers brian :D
Posted: Sat Feb 03, 2007 1:00 am
by marley_uk1
on my car the windows aint working but the sunroof is any ideas
Posted: Sat Feb 03, 2007 10:05 am
by Brianmoooore
marley_uk1 wrote:on my car the windows aint working but the sunroof is any ideas
If they boh stopped working at the same time, then probable culprit is the cut out switch. Either acting up, or a wire fallen off the back.
This assumes the wiring is as BMW intended, and hasn't been "got at".
Re:
Posted: Sat Feb 03, 2007 6:15 pm
by marley_uk1
where is the cutout switch
Re:
Posted: Sat Feb 03, 2007 6:30 pm
by Gortour
Cutout switch is the one in front of the drivers window switch.
Re:
Posted: Sat Feb 03, 2007 8:23 pm
by gooner1
Can also be on dashboard, next to hazzards.
