M42 belts & pulleys
Posted: Wed Jan 24, 2007 7:40 pm
by rc
Can anyone tell if the pulleys from an m44 (crank,water pump,alternator,PAS pump) all swap over to an m42(no air con) 8O... Does an m44 have tooth missin from its crank pulley same as 42 for crank sensor... thanks
Re: M42 belts & pulleys
Posted: Wed Jan 24, 2007 7:58 pm
by stuartgallafant
as far as i remember, the M44 uses the same timing as the M42 apart from it has a coil per cylinder, so effectively, everything should fit
why do you want to change it??
