Soaked passenger footwell
Posted: Thu Dec 07, 2006 12:29 pm
by camshaft
Hi Guys,
After a bit of advice please. Just bought a 325i 4dr with sunroof. I've noticed that the passenger footwell carpet is soaked thro. But the sides that fold up towards the dash and door are completly dry. Any ideas?
I've had the car jet washed and didn't notice anything leaking on that side of the car. I did however notice that the sunroof is leaking directly above the drivers seat.
Thanks in advance guys.
Re: Soaked passenger footwell
Posted: Thu Dec 07, 2006 12:35 pm
by Theo
Take the carpet out, and get the welding torch ready!
It's likely that the floorpan has rusted to the extent that water is coming straight through into the footwell.
Posted: Thu Dec 07, 2006 12:36 pm
by bazman
I had a leak in that footwell when i turned the heating off, was told it was the seal in the heater gone! Been too cold to turn it off hence no more leak. Perhaps yours is leaking? Must get round to fixing mine :mad:
HTH
Posted: Thu Dec 07, 2006 1:49 pm
by camshaft
Theo325 wrote:Take the carpet out, and get the welding torch ready!
I've just had it MOTd, would they have failed it for a rusty floor pan?
Posted: Thu Dec 07, 2006 1:58 pm
by camshaft
bazman wrote:I had a leak in that footwell when i turned the heating off, was told it was the seal in the heater gone! Been too cold to turn it off hence no more leak. Perhaps yours is leaking? Must get round to fixing mine :mad:
HTH
The car has been sitting on my drive for 2 weeks now, and I haven't used the heater yet. Could be? Only thing is, the carpet is only wet on the flat bit. The bits that turn up against the sides are completly dry.
The location of the wet is directly under the passenger side of the top corner of the windscreen, hence why I thought it was possibly the windscreen rubber. Will rip up the carpet tonight and have a look.
Any other ideas?
Posted: Thu Dec 07, 2006 8:30 pm
by Archie14f
Before you rip the car to bits try the easy bit first check the heater air inlet drain
located drivers side bulkhead flat piece of plastic dosent take much to block up.
Posted: Thu Dec 07, 2006 8:33 pm
by bmwe30mtech
As theo says probably a hole in the footwell unfortionaltly. 'Ripping up' the carpet is easy, and all will be revealed.
Posted: Thu Dec 07, 2006 8:47 pm
by jcjdavis1
Hi Have you cleaned out behind the scuttle panel and checked the elephants trunk is clear as that is where my prob. was.
Posted: Thu Dec 07, 2006 10:02 pm
by Brianmoooore
Water in the passenger side footwell, if not coolant from the heater valve, or from the scuttle because of a blocked drain, is usually a rusted front "jacking point" or rust around the big rubber grommet where the wiring comes through from the fusebox.
Posted: Thu Dec 07, 2006 10:10 pm
by SGP
You could have a look in the n/s wheel house pop the wheel off and check the bulk head,I've seen holes in here.
Posted: Thu Dec 07, 2006 10:17 pm
by Brianmoooore
SGP wrote:You could have a look in the n/s wheel house pop the wheel off and check the bulk head,I've seen holes in here.
These are usually holes that have spread from the grommet I mentioned. Getting towards terminal when it gets that bad.
Posted: Thu Dec 07, 2006 10:35 pm
by SGP
Yes, a mate bought a pre facelift 325i sport, paid top dollar for it,the bulkhead is totally rotten through, v.sad.All that salt they throw on the U.K roads during winter plays havoc.
Posted: Thu Dec 07, 2006 11:13 pm
by NH325CAB
How about drivers rear side? That footwell could've had ducks in it this morning! V upset... any ideas where that could be getting in from? Everywhere else is fine!
Posted: Thu Dec 07, 2006 11:33 pm
by Brianmoooore
NH325CAB wrote:How about drivers rear side? That footwell could've had ducks in it this morning! V upset... any ideas where that could be getting in from? Everywhere else is fine!
Assuming you mean water under the carpet, 85mm round plates in the floorpan, right under the front seat bases. The lugs that hold them in place rust off.
Posted: Fri Dec 08, 2006 9:22 am
by camshaft
Had a look under the car last night & lifted the carpet, there's no sign of rusty floor pan or any holes. I've sent the car to my mech to check out the heater & see if thats where the leak is coming from. All the other footwells are completely dry.
Thanks for your help guys, will let you know what the mech finds.
Posted: Sat Dec 09, 2006 10:25 pm
by kevin316i
Not sure if this is of help to you, but I had(still have?, not sure yet..) a leak in passenger side front foot well and sealed up the plastic grommets in the floor. Since then the leak seems to have stopped, but I'm not going to count my chickens yet...
Posted: Sun Dec 10, 2006 7:48 pm
by NH325CAB
Thanks for that.. will have a look tomorrow. An easy job to fix?
Posted: Sun Dec 10, 2006 10:34 pm
by kevin316i
Yep, I just prised them out and put some windscreen sealent around them, the stuff that stays flexible. Then just pushed them back in. Three weeks of almost constant rain here in the west of Ireland and still seems OK. Fingers crossed!
Posted: Wed Dec 13, 2006 1:40 pm
by camshaft
The Mechanic looked at this, and said it was the rubber grommet in the floor. He's sealed it up with some silicone, so hopefully this has been sorted now. Cheers guys for all your help. :)
Posted: Wed Dec 13, 2006 5:28 pm
by oze30
camshaft wrote:The Mechanic looked at this, and said it was the rubber grommet in the floor. He's sealed it up with some silicone, so hopefully this has been sorted now. Cheers guys for all your help. :)
Which rubber grommet!! Mines leaking too.. The carpets out so its abit easier, but the door seal is very damp across the top of the sills.
Anyone? Will try the grommet thing if I can find it!
I also have a whole in the scutle just below the a pillar on the pax side. Could it be coming in from there?
Posted: Wed Dec 13, 2006 8:51 pm
by Brianmoooore
There are no rubber grommets in the floorpan of an E30 that I know of. There are a few plastic grommets into some double skinned places, but I wouldn't normally expect much water to come in through these.
The hole in the scuttle is caused by shrinking sealant inside the bottom of the windscreen pillars. Water going in this hole will end up inside the scuttle and drain out of the " elephant's trunk" on the RH side of the engine bulkhead.
Posted: Wed Dec 13, 2006 8:55 pm
by Brianmoooore
kevin316i wrote:Yep, I just prised them out and put some windscreen sealent around them, the stuff that stays flexible. Then just pushed them back in. Three weeks of almost constant rain here in the west of Ireland and still seems OK. Fingers crossed!
They don't prise off, and they don't push back in. They are retained in a similar way to the fuel pump. I.E., by lugs on the plate and cut outs around the hole.
Turn to remove and refit.
Posted: Wed Dec 13, 2006 10:38 pm
by oze30
Is there anyway that water thur the scuttle in the A Pillar to come back thru the door frame/sill and soak the rubber seal?
Posted: Wed Dec 13, 2006 10:59 pm
by kevin316i
There are a couple of small flexible plastic grommets in the floor of the front passenger footwell, one of them is on the upward sloping part and I found a very small amount of water leaking through this. There are a couple of other that are plastic coated metal with small tabs to hold them in place. When I sealed these up, the leak appears to have stopped.
Posted: Mon Feb 12, 2007 10:00 am
by camshaft
Ok guys, I've stripped the carpet out of the car & found out where the leak is coming from. A small hole (1cm) on the sloping bit of the bulkhead - here's a pic
Here's another pic of the footwell - may help others
