Power Steering Rack?
Posted: Sun Nov 26, 2006 11:14 am
by Pal318is
Guys,
What the best/quickest way of changing my power steering rack?? I have a spare one, that I now need to replace, as well as my front ARB which snapped
So my plan is to do both at the same time..
Any advice would be greatly appreciated/welcomed.
Pal
Re: Power Steering Rack?
Posted: Sun Nov 26, 2006 11:55 am
by zaust
Drop the front sub frame as it will make all much easier for the rack. and the rool bar, I still struggle with them..
but it is easier to place when load is on the front of the car..
Posted: Sun Nov 26, 2006 12:58 pm
by Pal318is
i got all the u joint, atill attached to it. Is this easy enough to replace too?
Pal
Posted: Sun Nov 26, 2006 2:36 pm
by Brianmoooore
Rack can be changed OK without dropping subframes! Helps on a six pot if you bend the lower mounting tabs down a bit, but I thought it was easier on a four pot.
Fit the left hand rack bolt first and push the right hand side back into position while guiding on the steering coupling. On the rear coupling the clamp bolt locates into a groove in the column shaft, so, if after fitting this, the right hand side of the rack doesn't line up with the fixing holes, slacken the lower clamp bolt and slide this on the rack splines until it does.
Posted: Sun Nov 26, 2006 5:49 pm
by Pal318is
I have a 4 pot bud...
Any other peeps with some personal knowledge of this...
Pal
Posted: Sun Nov 26, 2006 6:44 pm
by Jamesb318is
As Brian says basically. I changed mine a while ago, no need to remove the subframe, comes out easy on a four pot.
Make sure you've got the seals you need, (for the banjo bolts) and fluid to refill.
Posted: Sun Nov 26, 2006 7:14 pm
by Brianmoooore
Jamesb318is wrote: and fluid to refill.
Fluid to flush is more important. Have about three litres handy to do the job properly.
Posted: Sun Nov 26, 2006 7:16 pm
by Jamesb318is
Good point!
Posted: Sun Nov 26, 2006 10:07 pm
by Pal318is
Thanks guys.
Posted: Mon Nov 27, 2006 6:16 pm
by Pal318is
Guys I have attempted this today and due to my inability to not know what i'm doing, i'm stuck
I have taken the off the 2 bolts behind the hub's, I have also taken off the 2 bolts that attach the rack to the sub frame, what else do I need to do? The rack is joined onto the u-joint that leads to the steering column, how does this come off? as i'm finding this quite tricky. Do I need to take off the ARB to get to it properly.
Also do I just pop out the tie rods from behind the hub's.
All help welcomed and appreciated.
Pal
Posted: Mon Nov 27, 2006 7:03 pm
by Pal318is
Anyone
Posted: Mon Nov 27, 2006 7:19 pm
by Martinaston
Have you dropped the subframe ?
Posted: Mon Nov 27, 2006 7:22 pm
by Pal318is
Martinaston wrote:Have you dropped the subframe ?
No..In a word.
Everyone's said that it's a piece of piss and that there's no need to drop the sub frame...I have a iS by the way. I taken the pump/reseviour off but got stuck with the rack
Pal
Posted: Mon Nov 27, 2006 7:27 pm
by TheDutch
If you haven't already, you'll need a ball-joint splitter to part the track rod ends from the hubs (a mallet may do the trick).
Steering coupling should be held in by one bolt, which you hopefully have found and removed. I found it helpful to open up the steering coupling splined joint by firmly whacking a fairly thick flat blade screwdriver in the split, along with a good dose of WD40.
If you haven't already you will want to remove the high pressure hoses and drain the fluid. After that, and with a little persuasion, it should hopefully come free.
Edit: If this is on a 318is I had absolutely no need to remove the subframe.
Double Edit: little persuasion means big hammers
Posted: Mon Nov 27, 2006 7:45 pm
by Pal318is
TheDutch wrote:If you haven't already, you'll need a ball-joint splitter to part the track rod ends from the hubs (a mallet may do the trick).
It's the steering coupling joint nut that is a pain to get too..
Unable to remove so far.
I've done all the hoses, from the pump and the resevoiur.
Pal
Posted: Mon Nov 27, 2006 7:54 pm
by TheDutch
Pal318is wrote:It's the steering coupling joint nut that is a pain to get to..
I seem to remember using at least one fairly long extender for this and, quite possibly, an assistant to hold it whilst I fumbled around underneath with a spanner. It can certainly be frustrating, especially in this weather.
Posted: Mon Nov 27, 2006 7:57 pm
by Pal318is
I hope it's easier to put back
Thanks for the help.
Pal
Posted: Mon Nov 27, 2006 11:13 pm
by Brianmoooore
Pal318is wrote:I hope it's easier to put back
Unfortunately not! The steering coupling joint can be quite fun to get back on.
Posted: Tue Nov 28, 2006 7:34 am
by Pal318is
Brianmoooore wrote:Pal318is wrote:I hope it's easier to put back
I knew it
Posted: Tue Nov 28, 2006 1:43 pm
by charlie316
This is'nt filling me with confidence!! I am planning to changemy steering rack this weekend!!
Posted: Tue Nov 28, 2006 2:20 pm
by Pal318is
I have just finished doing this mother of a job, maybe it's a mother coz it's the first time i've done it
but it was definately a MOTHER..
Has anyone got any ideas on how to flush the system?? Is there a bolt on the bottom of the rack that can be undone, so as to clean what's inside?? Also if it is a 19mm bolt then cool, but if not can someone give me some pointers on how to flush the system please..
Thanks Again.....Just the ARB now
Pal
Posted: Tue Nov 28, 2006 2:36 pm
by cliffybabe
Pal, ur lucky ur stil with it mate when i done my rack i knocked myself out
Posted: Tue Nov 28, 2006 2:59 pm
by Pal318is
cliffybabe wrote:Pal, ur lucky ur stil with it mate when i done my rack i knocked myself out
Quality....I've got a few cuts and bruises fo my troubles....
You wouldn't know how to drain the rack would you bud??
Pal
Posted: Tue Nov 28, 2006 3:06 pm
by cliffybabe
Pal
I drained mine by syringing out the PAS reservoir, Disconnected one of the main feed pipe's and let it drain out.
Posted: Tue Nov 28, 2006 4:17 pm
by Pal318is
Pal
Cheers Fella
Posted: Tue Nov 28, 2006 8:29 pm
by Brianmoooore
To flush the system I remove the return hose from the resevoir, block the pipe stub on the resevoir (I actually push on another piece of pipe and double it back so that the end is higher than the resevoir.) and extend the return hose into a bowl.
Pull out fuse 11 to kill the fuel pump, fill the resevoir, and crank the engine over while turning the steering wheel from full lock to full lock. Helps to have someone topping up the resevoir while you do this.
Keep going until clean fluid starts coming out into the bowl.
All together a messy job which is not my favourite!
Posted: Tue Nov 28, 2006 10:37 pm
by Pal318is
Brianmoooore wrote:To flush the system I remove the return hose from the resevoir, block the pipe stub on the resevoir (I actually push on another piece of pipe and double it back so that the end is higher than the resevoir.) and extend the return hose into a bowl.
Your a Gem Brian
Thanks Bud.
Pal
Posted: Sun Dec 03, 2006 6:01 pm
by charlie316
Got round to replacing my steering rack today! Never wanna do that again, the hardest bit is getting the old one out once all the bolts are undone. Ended up bending the brackets right out of the way. Also my steering wheel is now 45 degrees out oops!
Thank god its done though.
Posted: Sun Dec 03, 2006 6:13 pm
by cliffybabe
charlie316 wrote:Got round to replacing my steering rack today! Never wanna do that again, the hardest bit is getting the old one out once all the bolts are undone. Ended up bending the brackets right out of the way. Also my steering wheel is now 45 degrees out oops!
dude i told u it was a complete bitch of a job
have u lowered her yet??
Posted: Sun Dec 03, 2006 6:15 pm
by charlie316
It really was a bitch. No not lowered it yet, thinking i'll get it registered over here and get the insurance sorted then lower it.
Posted: Mon Dec 04, 2006 3:02 pm
by Pal318is
Not only is the Power Steering rack a bitch to do...i found out that the front ARB is also a bitch too
Took me ages to do both. No one after the other, mind you
Posted: Mon Dec 04, 2006 6:32 pm
by charlie316
Just driven back from uni now and it has started making a consistent knocking noice! Dam this car, you can feel it when you hang off the front right wheel too. Im sure i tightened everything.
Any ideas?
