325 cutting out (repost)
Posted: Tue Nov 21, 2006 5:54 pm
by littlejim
Sometimes when I start my 86 325 it runs fine for a minute and then just cuts out,
it just stops, no missfires or spluttering and will not fire up. :cry:
other times it runs fine. :D
fuel pump fuse is ok, I haven't changed the relay yet (there arn't any with the same part no to swap it with in my fuse box)
I tryed bridging the relay connectors when it wouldn't run but still wouldn't fire up.
I thought fuel pumps just stop altogether when they wear out?
I have changed the blue temp sensor and cleaned out the ICV,
changed the plugs, leads, cap and rotor arm,
tested the coil and fly wheel sensors
Posted: Tue Nov 21, 2006 5:59 pm
by Richy325iTouring
try one of the relays on the n/s wing
Posted: Tue Nov 21, 2006 6:21 pm
by littlejim
I tryed bridging terminals 30 and 87 on the fuel pump relay but it still wouldn't fire up, it might be flooded I will try again tomorrow.
Re:
Posted: Tue Nov 21, 2006 6:33 pm
by Richy325iTouring
i fixed one yesterday with same problem by changing the white relay
my touring also had the same problem
id put my money on that
