Overheating when idle?
Posted: Mon Oct 30, 2006 12:36 am
Hello all,
A quick question regarding an odd overheating scenario that I'm currently experiencing.
When the car has warmed up and is idling for a few minutes, I notice that the temperature needle will creep up past the halfway mark and usually sits just below the 3/4 line.
As soon as I start moving the car, the temp will drop back to under the halfway mark.
Can anyone suggest what a likely culprit would be? Consider that I've had the following changed in the last 2 months:
- viscous coupling (new)
- fan belt (new)
- thermostat (new)
- radiator (2nd hand, 3 months old)
- antifreeze replaced last week and radiator bled properly, coolant level in radiator seems stable.
Thoughts?
Ben
- fan belt (new)
- thermostat (new)
Thoughts?
Ben
