weird brakes.
Posted: Thu Oct 26, 2006 8:27 pm
by liam012
well just did the rear disc conversion which consisted of calipers arms hubs the whole lot swapped over - stainless hoses and new pagid pads - however tthere have been some problems - the car just has no brakes right down nto almost the floor and then they lock up? have swapped out the master cylinder with one that appeared to be in better condition but to no avail- what else could be causing such a deep (far travel) pedal?
Re: weird brakes.
Posted: Thu Oct 26, 2006 9:13 pm
by mark320i
ive just had the exact same problem, did the rear disc conversion
and theres barely any brakes? is this just bacause there new? sorry to
jump in here liam but made sense instead of starting a new post seen as
i think we have the same problem.
Re: weird brakes.
Posted: Thu Oct 26, 2006 9:35 pm
by Ant
iirc, the drum braked cars have a PRV in the system somewhere
have a peek under the master cylinder.
Re: weird brakes.
Posted: Thu Oct 26, 2006 9:47 pm
by liam012
whats a prv?! and can it be removed/changed adjusted?
OT-Got first drive today Ant - chip is on the money - cant wait to install the ms after the run in.
