bottom ball joint??
Posted: Fri Oct 13, 2006 2:46 pm
by E30_320i
hi ppl
ive just popped into blue bell, crewe and asked how much a bottom ball joint for the E30 was.
anyway after a few moments he came back and said "Ԛ£110" so i laughed and said "Ԛ£110 for a bottom ball joint?" and he said that you have to replace the whole arm!
is this true? plz tell me it isnt!
Re: bottom ball joint??
Posted: Fri Oct 13, 2006 2:55 pm
by E30Mark
Go to ECP or GSF etc the arms there are about Ԛ£30 all in.
Posted: Fri Oct 13, 2006 3:18 pm
by E30_320i
okie, cheers mark!
Posted: Fri Oct 13, 2006 10:49 pm
by chief
if you repalce the arm make sure you get the new bush, as they don't include in the pack.
27 quid for the arm and 6.75 for the bush. (GSF)
Re:
Posted: Sat Oct 14, 2006 12:27 am
by Brianmoooore
Just to complicate things a bit, GSF/ECP sell the individual ball joints as well for pressing into your existing arm.
If you think that quote from the dealer was high, then try asking them for the same part for a 325 touring!
Re:
Posted: Sun Oct 15, 2006 11:31 pm
by E30_320i
yeah brian i did notice the inner and outer ball joints :-s, so does this mean i can just buy the ball joint off GSF?? if so thatd be great, bcuz thats all i need.
yeah i did read somewhere that bmw main dealers are the most expensive! i can believe that!
Re:
Posted: Sun Oct 15, 2006 11:47 pm
by Brianmoooore
Not necessarily for everything. They can surprise you sometimes.
Yes, you can just change the individual joint on a steel arm.
Re:
Posted: Wed Oct 18, 2006 2:46 pm
by evostormm
Can you press out the joint on an alloy (Touring) arm too? Or is that not recommended?
Re:
Posted: Wed Oct 18, 2006 8:33 pm
by Brianmoooore
Definitely not recommended, I'm afraid.
