steering prob fix
Posted: Fri Oct 06, 2006 8:56 pm
by robbo80
i have had stiff steering for about 2 months ant the steering wheel squeeled earpearcingly high pitched as if it was rubbing where it fits on . earlier today i was turning in the road and i felt something slip back into place and my steering is completly fine now . does anyone know what this could be and how to stop it again . cheers
Re: steering prob fix
Posted: Fri Oct 06, 2006 9:28 pm
by gareth
pas belt slipping?
Posted: Fri Oct 06, 2006 9:30 pm
by Chris-W
A bit a crap on your horn ring (excuse the phrase)?
Posted: Fri Oct 06, 2006 9:33 pm
by DRIFTBOY
A bit of dirt or blocking something or a sticking valve in the pump or rack that has just freed itself ???
Posted: Fri Oct 06, 2006 9:36 pm
by robbo80
where is the horn ring and if that is the case why did it stop completly when the steering went back to normal. it felt more like a ball joint slipping into place more than a belt slipping , is this possible .
Posted: Fri Oct 06, 2006 9:56 pm
by gareth
a dodgy pas pump will make a grating noise that will increase in pitch with engine revs...
Posted: Sat Oct 07, 2006 10:23 am
by Wookie
Is there any way one can repair a dodgy pump? I've heard you can strip the pump and clean it, but does this work?
Posted: Sat Oct 07, 2006 10:47 am
by gareth
it must be possible but to be honest not really worth it. they're so cheap from a breaker.
Posted: Sat Oct 07, 2006 10:49 am
by DaveD
when was the last time you flushed the system?
