Check panel faults
Posted: Mon Oct 02, 2006 9:53 pm
by exup
Hi ,
my check panel keeps coming up with " brake lights",
I ve checked that both rear brake light s are working ok , i took the bulbs out and cleaned them up any way , but the brake lights keeps coming up , is there any common faults to chck over ,
any idears ?????
thanks
Re: Check panel faults
Posted: Mon Oct 02, 2006 10:14 pm
by Brianmoooore
First, try 2 new good quality bulbs, and then suspect the brake light switch and/or the adjustment of the brake linkage pull rod that goes across the car in front of the heater.
Posted: Tue Oct 03, 2006 8:35 am
by Chris-W
Does the light stay on all the time?
Posted: Tue Oct 03, 2006 8:02 pm
by exup
Thanks Brian , will try your suggestions,
No the light comes up some times , but not all the time , has nt done it at all today ?
Posted: Thu Oct 05, 2006 7:24 pm
by exup
For info to all , i tried every thing
but it was a faulty brake like light b switch, it was working ie bring on the rea brake lights ok , but was not reseting the check panel light ???
swoppped for another and its all ok now
thanks all
Posted: Thu Oct 05, 2006 8:55 pm
by Brianmoooore
If the brake switch doesn't work cleanly it will light the chack panel.
Posted: Fri Oct 06, 2006 5:12 pm
by exup
Thanks as all ways Brian
i beleive you have fitted lpg to m20 lumps b 4 ?
is that single pint or mutli point systems ??
brake light check panel.
Posted: Fri Oct 06, 2006 5:19 pm
by H-M3
Sorry to jack the thread, my car seems to have the same problem!!
Guys where is this brake light switch located then?
cheers
Posted: Fri Oct 06, 2006 8:09 pm
by Brianmoooore
Single point. Multi point is a bit OTT for a M20.
M50B25 engined touring will get a multi point system I have here ready when I get the time though.
Re: brake light check panel.
Posted: Fri Oct 06, 2006 9:33 pm
by Chris-W
H-M3 wrote:Sorry to jack the thread, my car seems to have the same problem!!
cheers
Behind the brake pedal, at the top.
Posted: Mon Oct 09, 2006 1:59 pm
by H-M3
Chris-W wrote:H-M3 wrote:Sorry to jack the thread, my car seems to have the same problem!!
cheers
Cheers Chris
