Pedal box removal?
Posted: Mon Aug 28, 2006 8:22 pm
by eko
Bit of advice please guys.
Need to remove the peddle box from my breaker for an auto conversion.
Started taking the dash out earlier,almost done.
Question is,how do the pedals come out?
I mean,is it the complete assembly that i have to change or can i simply remove the clutch and brake pedals and refit these in the auto?
Any help appreciated
Re: Pedal box removal?
Posted: Mon Aug 28, 2006 8:38 pm
by stevetigger
Posted: Mon Aug 28, 2006 8:44 pm
by eko
Nice one Steve.
Looking at that,it looks like i may have to change the full assembly in one.
Is this possible without stripping the whole thing into bits?
Can anyone who has done this confirm?
Posted: Mon Aug 28, 2006 9:05 pm
by smithy318i
it comes out in one big chunk. iirc there are about 6 nuts holding it to the bodywork. The brake rod also needs to be lossened.
Posted: Mon Aug 28, 2006 9:06 pm
by eko
smithy318i wrote:it comes out in one big chunk. iirc there are about 6 nuts holding it to the bodywork. The brake rod also needs to be lossened.
Smithy your a star-thats what i needed to hear!
Accelerator linkage part of main assembly or seperate?
Posted: Mon Aug 28, 2006 9:12 pm
by smithy318i
linkage is part of assy, except the pedal itself.
Posted: Mon Aug 28, 2006 9:18 pm
by eko
Nice one Smithy,now i know what to expect/do,thanks mate
Posted: Mon Aug 28, 2006 9:35 pm
by stevetigger
Thought it came out in one, but didn't want to say in case I was wrong again!
Posted: Mon Aug 28, 2006 9:38 pm
by eko
stevetigger wrote:Thought it came out in one, but didn't want to say in case I was wrong again!
but Steve your never wrong...........
Posted: Mon Aug 28, 2006 9:42 pm
by stevetigger
Only when I am right!
Posted: Tue Aug 29, 2006 9:13 am
by Quaser
10 bolts, and a circlip for the brake rod.
Also needs to remove slave cylinder. Easy Peasy
Posted: Fri Sep 01, 2006 6:30 pm
by eko
Right guys i got the pedal box out today but need to check a couple of things with someone in the know!
When removing the pedal box i couldnt see the clip holding the linkage bar to it,so i just `forced`it out from behind the heater box
Looking at it now i can see the pin and clip but its in upside down?meaning the isnt enought room to withdraw it
So can i release the lock nut and unscrew the rod thus leaving it in place?
Also i removed the full dash on the breaker to get to the pedal box,will this be nessarsary on the new car or can i work around it?
Posted: Fri Sep 01, 2006 10:50 pm
by Quaser
as long as you screw the rod in exactly the correct position, it should be ok.
the dash can stay on the car
Posted: Fri Sep 01, 2006 10:52 pm
by eko
Quaser wrote:as long as you screw the rod in exactly the correct position, it should be ok.
Youve made my day,thanks mate
