New wheels
Posted: Tue Aug 01, 2006 1:24 pm
by swindy
Hey all its been a while scince I was on here but after fitting new tyres found my wheels to be a tad buckled, so new wheels needed i want to go 16's deeeeeeeep dish, what is the standard offset and hole gap? They say things like et and that, not a clue what it all means, any help? Any pictures of deep dish 16's?
Cheers Mark.
Re: New wheels
Posted: Tue Aug 01, 2006 2:16 pm
by oze30
I think you mean "spigot".. its the hole in the middle of a wheel that sits on a little lip that centres the wheel. Not sure what size it is, but try typing spigot into the search.
Re: New wheels
Posted: Wed Aug 02, 2006 9:40 am
by swindy
Thanks for that but no I mean what offset or E30 wheels and what PDC or they?
Re: New wheels
Posted: Wed Aug 02, 2006 10:11 am
by massive
4x100 pcd
I think its ET24 but I maybe mistaken
Re: New wheels
Posted: Wed Aug 02, 2006 10:49 am
by papadakisn
I was wondering the same thing.
What is the maximum offset (ET) someone can do on lets say 16 inch wheels (on a lowered E30 318i) ?
The factory 15s are what offset ? I also like deep dish wheels but don't want to go over 16 inches.
You can take a look at Tirerack.com for examples.
Re: New wheels
Posted: Wed Aug 02, 2006 11:11 am
by massive
The facory bbs rims are ET24. If you increase the ET you would then need to use spacers. E.g If you had say ET35 rims if you used 11mm spacers, this would then make ET24 which would sit correctly.
Its best to get close to ET24 as possible as thick spacers could cause problems i.e. needing longer bolts
HTH
Re: New wheels
Posted: Wed Aug 02, 2006 11:33 am
by papadakisn
That was stupid of me...
I was thinking "wider" so I really meant how LOW can we take the offset for lets say 7X16 wheels.
Would we encounter any rubbing on a lowered vehicle (35-40mm) ?
I would try to get the wheels where I want by ordering wheels with the correct offset (to put them where I want them), and not using spacers.
Re: New wheels
Posted: Wed Aug 02, 2006 11:42 am
by TheRealest
i'm runnin 2 x 16x7.5 and 2x 16x9 borbet A on my e30, sure they r et20 but a lot depends on how decked ur car is and wot tyres u put on the rims, i run 215/40 on the rears which pull the sidewalls right in but still managed to rub like fuck on my old suspension set up.
Re: New wheels
Posted: Wed Aug 02, 2006 11:55 am
by d6dph
massive wrote:The facory bbs rims are ET24. If you increase the ET you would then need to use spacers. E.g If you had say ET35 rims if you used 11mm spacers, this would then make ET24 which would sit correctly.
HTH
That only works if you are using the same width, wider wheels need the offset changing from factory ET depending on the dish etc
Re: New wheels
Posted: Wed Aug 02, 2006 12:06 pm
by massive
d6dph wrote:massive wrote:The facory bbs rims are ET24. If you increase the ET you would then need to use spacers. E.g If you had say ET35 rims if you used 11mm spacers, this would then make ET24 which would sit correctly.
HTH
Yes agree, if they are dished, they naturally give a negative offset
Posted: Wed Aug 02, 2006 12:09 pm
by bigpimpin
Re: New wheels
Posted: Wed Aug 02, 2006 12:14 pm
by d6dph
massive wrote:d6dph wrote:massive wrote:The facory bbs rims are ET24. If you increase the ET you would then need to use spacers. E.g If you had say ET35 rims if you used 11mm spacers, this would then make ET24 which would sit correctly.
HTH
Sorry, wasnt trying to be funny with you, just re-read my comment and it sounded a bit rude.
Re: New wheels
Posted: Wed Aug 02, 2006 2:24 pm
by swindy
et24 4x100pdc cheers boys and girls. shouldnt matter what dish there are so long as they state they are et24 should it. Can you tell I have NEVER bought after market wheel before?
Thanks again, mark.
Re: New wheels
Posted: Wed Aug 02, 2006 2:30 pm
by massive
No offence taken matey, didnt think it sounded funny at all
Re: New wheels
Posted: Wed Aug 02, 2006 2:35 pm
by massive
swindy wrote:et24 4x100pdc cheers boys and girls. shouldnt matter what dish there are so long as they state they are et24 should it. Can you tell I have NEVER bought after market wheel before?
Thanks again, mark.
Well no, ET24 is the standard fitment for the bmw bbs rims. If you go wider or go with a dish you have to compensate the offset. Bigpimpin gave a web link which calculates everything you need to know.....scroll down to E30 and find your proposed wheel & tyre size. It then tells you the correct ET number. If for any reason you cant find that offset for the rims you want, you will have to find the closest and use spacers.
The pcd obviously doesnt change
Re: New wheels
Posted: Wed Aug 02, 2006 10:55 pm
by swindy
gotch cheers guys I think I get it now.
Re: New wheels
Posted: Wed Aug 02, 2006 11:06 pm
by dazleeds
also depends a lot on the shape of the spokes too
the ats cups on the Is wouldnt clear the front calipers or track rods till i stuck 5mm on but they are et20
also my azevs 16s had same prob spokes hit calipers
