how much £ do i need to spend to lower my 320i
Posted: Sat Jul 08, 2006 2:21 pm
by dom-1984-320i
hey guys,
am just pricing up the forth coming jobs to do on my 320i and wondered roughly how much i should be paying to get the car lowered 35 of 40 all round? Dont want to get ripped of so any help would be greatly appreciated.
cheers
Posted: Sat Jul 08, 2006 2:29 pm
by smithy318i
to DIY... about 50-60 quid
Posted: Sat Jul 08, 2006 2:30 pm
by Project_E30
How?
What would you buy for the fronts and from where?
Posted: Sat Jul 08, 2006 2:49 pm
by dom-1984-320i
do i need shocks and springs? is this the best thing to do?
Posted: Sat Jul 08, 2006 2:55 pm
by dom-1984-320i
hey there,
50 or 60 quid how could i do it for that? sounds very cheep!
Posted: Sat Jul 08, 2006 2:56 pm
by smithy318i
I didnt need new shocks when i lowered mine. new springs, a set of spring compressors and a ball joint splitter were all i needed.
Posted: Sat Jul 08, 2006 3:39 pm
by georob
Check the forum here from time to time, i'm sure someone was selling a set of lowering springs for £30.
Posted: Sat Jul 08, 2006 5:03 pm
by m-dtech
i have a set of springs brand new i bought for my 320i but i now have a 318i and now no use to me.
never fitted.
£35 + p&p
pm me if interested
Posted: Sat Jul 08, 2006 7:47 pm
by Bob_S
I didnt use a ball joint splitter last time i changed front shockers, I just unscrewed the track rod end but marked where it was?
Posted: Sat Jul 08, 2006 7:52 pm
by smithy318i
Bob_S wrote:I didnt use a ball joint splitter last time i changed front shockers, I just unscrewed the track rod end but marked where it was?
what about the lower wishbone mount ?
he will
need a ball joint splitter.
Posted: Sat Jul 08, 2006 8:23 pm
by georob
smithy318i wrote:Bob_S wrote:I didnt use a ball joint splitter last time i changed front shockers, I just unscrewed the track rod end but marked where it was?
he will
two hammers would suffice instead, hit either side at the same time usually splits them ok for me
Posted: Sat Jul 08, 2006 8:39 pm
by fuzzy
bob-s ,how did you unscrew the track rod end without disconnecting the ball joint? are you planning to do the job yourself?its relatively straight forward with the only possible problems being bolts that have siezed on but nothing a bit brute force cant fix.i dont use ball joint splitters as mine tends to rip the rubber.i screw an old nut on top to protect the threads then belt with a hammer .id also recommend spring compressors.you might be lucky and not need new shocks but if theyre old then id change them anyway whilst its apart.id recommend buying m-dtechs springs as hes a decent guy
Posted: Sat Jul 08, 2006 10:49 pm
by irish320i
[quote="fuzzy"]bob-s ,how did you unscrew the track rod end without disconnecting the ball joint? you can just unscrew the shaft that goes into the ball joint the same as you do when tracking the car
Posted: Sun Jul 09, 2006 2:55 pm
by Bob_S
thats exactly what I did just unscrewed the inner arm that you use for tracking adjustment a bit crude but works generally and you dont knacker anything up
I used the old technique of a nut on top of the thread and belt with a hammer on the main ball joint works a treat everytime
I find the same that the ball joint splitter always buggers up the rubber on the joint
Posted: Sun Jul 09, 2006 9:49 pm
by Brianmoooore
Yet another use for silicon grease.
Rub some over the cover and on to the forks of the splitter. Works most times.
Re: how much £ do i need to spend to lower my 320i
Posted: Mon Jul 10, 2006 2:37 am
by slideways
if u hit the nut be it an old one or not u are gonna make an arse of the threads one or an other. it aint your mum, bloody wallop it good and hard, not the joint the stub axle when it is on full lock. never ever had to use gas on any joint yet and dont plan to either..
when changing the shocks on my sport had a right job opening the collar on the strut top to get out the shock. some knob jockey had tightened it with a hammer and chisel..
Posted: Mon Jul 10, 2006 6:39 pm
by Bob_S
blow torches and footprint grips are the future mate ;)
