Spiggot ring/Hub size??
Posted: Fri Jul 07, 2006 6:30 pm
by JAMZ
Can anyone tell me what size spiggots i gota get..? need um urgently
cheers
Posted: Fri Jul 07, 2006 8:38 pm
by JAMZ
Anyone..?
need to know the hub sizes of the E30 asap..and hope where im going tommorrow keeps that type in stock :? or its another weekend not being able to drive the car.
Posted: Fri Jul 07, 2006 8:42 pm
by telski789
hi,im sure all e30 hubs are the same but i know that if you have a 325i the hubs are 57mm,the outside diameter of the rings depends on the wheels,mine needed an outside measurement of 60mm,meaning mine are very thin! so,measure the hole in the wheel where the hub go's and you'll know your size. also,mention the make of the wheels as the rings are best to come from the maker of the wheels as the vary in design....hope that helps,also,i have a couple of sets of rings so let me know what your after...
Tel
Posted: Fri Jul 07, 2006 8:52 pm
by JAMZ
Well im fitting RH Toplines to the CaB but they havent got Spigots included..
So basicaly the inside is 57mm
and the outside measurment would be the centre diameter of the wheel..
I just mesured the centre hole diameter and its 57mm too
Posted: Fri Jul 07, 2006 8:59 pm
by telski789
you dont need rings then!! have you tried them on yet?!!
Posted: Fri Jul 07, 2006 9:03 pm
by JAMZ
Thats what im hopeing.. no hanvet tried em yet.. pretty sure these came off a VW so i assumed i would need spigots as i thought they had different size hubs? :?
Posted: Sat Jul 08, 2006 12:51 am
by slideways
put them on and get shop us apic when you done..!!!
Posted: Sat Jul 08, 2006 11:01 am
by telski789
im sure vw golf hubs are bigger,infact,my mates had to have rings at the back but not the front on his,coz the front and rear hubs were different sizes!
Tel
Posted: Sat Jul 08, 2006 11:13 am
by massive
JAMZ wrote:Well im fitting RH Toplines to the CaB but they havent got Spigots included..
:clap: Excellent choice of rims - your cabby is gonna to look :cool: as fcuk!
I need rings for my toplines on my 91 sport if that helps, but not sure on the sizes :mad:
d
Posted: Sat Jul 08, 2006 11:19 am
by panesar_e30
wassup jamz, you may need spiggot rings depending on what car they came off. as long as they fit tight on the hub you will be fine, if not, you will get severe juddering. hope this helps! winkeye
