discs
Posted: Wed Jun 28, 2006 9:58 pm
by robbiehartge
what the best upgrad discs to buy 4 my h26.
Posted: Wed Jun 28, 2006 11:04 pm
by Lordschleife
Dunno what size they are on the H26?
If std then either stock BMW are fine, or ATE power discs (from ECP) are good if you want grooved - thats what i use
Posted: Thu Jun 29, 2006 5:01 pm
by robbiehartge
how about rossinis.
Posted: Thu Jun 29, 2006 10:19 pm
by Lordschleife
They're drilled and drilled discs can be prone to cracking - a good modern pad shouldnt create much gas anyway, so the holes are a bit pointless, a grooved disc should allow some gas to escape anyway
If you're looking to improve your braking performance (without fitting bigger discs/callipers) then upgrading your pads and fluid will make by far the biggest difference
Ferodo DS2500 pads are great but pricey, mintex 1155 are a bit cheaper and supposed to be good
Fluid wise go for Motul RBF600
Then maybe think about some braided hoses for better feel
If you really want new discs then go for the ATE power discs I suggested above - they were good enough to win the nÃarburgring 24hr in an m3
