what should i replace on m50 engine before install
Posted: Sat Jun 03, 2006 11:25 pm
by irish320i
i have the engine out of the 5 and was wondering what i should replace before i install it in the e30
Posted: Sun Jun 04, 2006 11:34 am
by Ant
Sump gasket as they do tend to weep a bit after time
replace the copper washer for the camchain tensioner too, common place for oil to pi$$ out on the M50
do the brether pipes( they split) and R/cover gasket while its out of the car, you can inspect the cams then too and clear out the breather box inside the R/cover
everything else is pretty robust, I regularly service an M50B25 equipped E34 with 307K miles on it, strong as an ox still !
Posted: Sun Jun 04, 2006 1:08 pm
by DanThe
My timing chain cover gasket seems to be leaking, but now Ant's just mentioned the tensioner washer it may be that :?
Wish id have changed as much as possible with the engine out now :cry:
Posted: Sun Jun 04, 2006 7:49 pm
by Brianmoooore
Most important thing to check is the water pump. If it has a plastic rotor, then throw it as far as possible and replace it with a new one with a metal rotor.
Plastic water outlet elbows have been known to fracture as well. Fitting a new one will defer the disaster for several years, but early M50s had an alloy one.
cheers
Posted: Tue Jun 06, 2006 8:11 pm
by irish320i
ordered sump gasket, teromstat, rocker cover gasket , water pump, rear crank seal also was thinkinh of getting a new timing chain any need have any of yous heard of thyem breaking
Posted: Tue Jun 06, 2006 8:27 pm
by DanThe
Forgot about rear seal :oops:
The front one will need to be done with the engine in the car due to the 'special' technique :)
Heard of chains slipping but never a broken one
Posted: Thu Jun 08, 2006 10:34 am
by Gt6s
Check / replace clutch. Replace thrust bearing.
