Adjusting ta[[ets, garage says can still be rattly after
Posted: Thu May 25, 2006 8:56 am
by alan325i
Just phone a garage up and they said even when they are adjusted they can still rattle, is this correct?
Mine rattle only when cold and only for about 2 mins
They are going to charge £94.00 +VAT :mad: :mad: :mad:
Re: Adjusting ta[[ets, garage says can still be rattly after
Posted: Thu May 25, 2006 12:04 pm
by Gt6s
alan325i wrote:Just phone a garage up and they said even when they are adjusted they can still rattle, is this correct?
£ 94 + vat an hour !
Wear on cam and rockers is usual.
Std BMW TICK, TICK, TICK.
Adjusting can quieten for a while, but not £ 94 + vats worth.
Posted: Thu May 25, 2006 6:21 pm
by alan325i
i phoned up the Dealers and even they only charge £70 inc VAT so not all garages are cheaper than dealers i have found 8O
Posted: Thu May 25, 2006 8:59 pm
by parksie
I've bin there & bought the T shirt!! :-x
My so called specialist said he needed the car overnight so that he could do the adjustments 1st thing in the morning ,after the £90 bill the tappet noise was still there 8O , the owner/specialist! then said the Cam must be worn .!! :twisted:
This proved to be true ,new cam 7 followers req+ usuall head work £ 700 latewr i ask the Question how is this wanker going around proporting to be a Bmw specialist, caring out tappet adjustments on a 120,000 engine & extorting money from the public, any specialist would surely understand that a 100K + engine needs a bit more than adjustment!!.
I no longer use that Garage ,but if like you say it's still noisy after being adjusted then suspect the cam, and also get a 2nd opinion :D
Posted: Thu May 25, 2006 10:03 pm
by Brianmoooore
parksie wrote:, any specialist would surely understand that a 100K + engine needs a bit more than adjustment!!.
Agree with the rest of your post, but there's no reason at all to expect anything to be worn on a properly maintained 100k+ BMW engine, or a 200k+ one for that matter.
Everything, except exhaust valve guides, was still well within new spec when I stripped a 200,000 mile M20 a while back.
Posted: Fri May 26, 2006 7:42 am
by parksie
Brian i admire your loyalty to the cause& i choose not to question your judgment, but unless a owner can vouch for the completeness of the cars service history ie owned from new, (and there aint many 1 owner 16 yr olds around )the cams / valves etc seem to fall victim of earlier inlife neglect :( i guess that was my point :D
Posted: Fri May 26, 2006 9:26 pm
by buffly
I myself am a BMW technician and have a 325 with a shrick cam fitted, and its a hell of a job to get the clearences spot on. They are better off a bit slack than too tight! Sounds pretty good at 7200rpm though!!!!
