Where to put axle stands
Posted: Tue May 23, 2006 8:48 am
by SD
Where are the best points under the e30 to place axle stands? May seem a bit of a daft question - but wasn't too happy with my choices last time I had the car up on stands.
Posted: Tue May 23, 2006 9:01 am
by Simon
On the front, under the chassis rail, I normally use something on the stand, a rear spring pad is a good idea, on the rear, I put it under the rear axle bush mount, though from what I gather it's not the best place to use!
Posted: Tue May 23, 2006 11:08 am
by Chris-W
If your sills aer good at the rear, then a stand with, as Simon says, a piece of hard rubber on top, placed under the sill at the jacking point is fine.
I've been forming a theory that using the axle bush mount as a jacking / stand point contributes to the likelihood of the bush cores breaking when you try to get them out!
Posted: Tue May 23, 2006 12:20 pm
by cliffybabe
under the car
Sorry it had to be done :twisted:
Posted: Tue May 23, 2006 1:56 pm
by SD
So that's where I was going wrong? :)
Posted: Tue May 23, 2006 2:08 pm
by Gt6s
cliffybabe wrote:under the car
I keep mine on a shelf, if they are under the car they are too hard to get to when you need them.
They also restrict the cars performance (That horrible sound they make)
