Electric window swirtches
Posted: Mon May 08, 2006 4:48 pm
by Fiona
Hi guys
noticec the other night for the first time my sunroof switch the electric window switches were all lit up when I went to my car??
is this normal should they stay on once the car is locked? or will this drain the battery???
Posted: Mon May 08, 2006 4:50 pm
by Fiona
Oh I have a M Tech 2 325i sport
Posted: Mon May 08, 2006 4:58 pm
by dazleeds
mine did this
stayed on constantly
it turned out to be the door pin wasnt connecting when it pushes in
try pushing it in with the door open to check it
Posted: Mon May 08, 2006 9:23 pm
by Brianmoooore
dazleeds wrote:mine did this
Door pin doesn't connect when it's pushed in - it disconnects.
Not unusual for the switch not to connect when the door is open, (same fault as when the interior lights don't come on), but it's very unusual for them not to disconnect when the door closes. Either the switch is broken or the wire's shorting inside the door pillar.
The switches should only be lit, (and the windows work), when the ignition is on, or the front doors are open.
