battery drain
Posted: Tue Mar 01, 2005 4:42 pm
by mattsbe3mer
hi guys
got a 1989 316i coupe with a power drain
I noticed when sitting in her at night with no key in ignition that the window, sunroof lights are still on and still operate. also the same with the OBC. Except its not bright and don't work the temp button when car ignition is off only time date. The windows and sunroof still work when the fuse is out. unless i took wrong one out.
any ideas
Posted: Tue Mar 01, 2005 5:22 pm
by M3RAGS
whats it like when the car is idling? does the hazard button light get brigher when you rev the car?
Could be a few problems, like a duff voltage regulator, duff alternator, loose belt, duff bushes or a duff battery.
Going to need more than that mate,....
Posted: Tue Mar 01, 2005 6:08 pm
by mattsbe3mer
not sure. ill have to use the booster again.
I used a tool and it said that the battery was charging well when ignition is on.
would the windows and sunroof work if car is switched off?
Posted: Tue Mar 01, 2005 6:13 pm
by telski789
ive had the same problem today,battery dead,just wont hold charge
Tel
Posted: Tue Mar 01, 2005 7:53 pm
by mattsbe3mer
I didn't relise the windows and roof work where suppose to work when ignition is off when the door is open.
I pushed (with my finger) in the little nob on spring thing that turns off the lights when door is closed. the window and sunroof stop working and the lights go off.
The thing is when i close the door, the lights don't go out. (same thing happens with the boot) I'm wondering if the door is actually pushing this thing in.
any ideas how to sort this lol thanks
Posted: Wed Mar 02, 2005 11:44 am
by SeamanStaines
Hello Matt
It could be a broken spring in the door pin - a trip to the scrapyard is the best option although a new one won't be much. As a temporary thing, add a couple of self adhesive sticky pads (for number plates and interior mirrors) on the inside of the door where the door pin touches. This will press the door pin in more and could solve the problem.
Posted: Wed Mar 02, 2005 5:27 pm
by mattsbe3mer
HEY SS
Thanks for the responce. I was up in the snow trying to cure this at about 3:00 in moring. I need to charge the batt now lol zzz
thanks mate.
I also need to adjust the boot lid as thew boot one stays on.
thanks guys
