318is modifications for the track (and a road car)
Posted: Fri Apr 14, 2006 10:04 pm
by Jem
I've currently got a M40 powered 318i, which is great as a daily run around, but I'm looking to start doing 7 or 8 trackdays a year. I'm thinking of selling the the 318i and buying a 318is to use as my daily drive and for doing trackdays. What modifications would you guys suggest making to a 318is for the track?
Posted: Fri Apr 14, 2006 10:08 pm
by m3ben05
Why not just keep the 318i as a road car then buy a 325 as a track car? The 325 is not much more expensive than the 318is and a lot more powerful.
As far as mods go,
Decent suspension/ bushes
Uprate the pads, disks and get some braided hoses
Strip out the interior, fit a roll cage and a couple of bucket seats
That will do you for starters, if you want more you could -
track tyres (yoko a048's)
fibreglass panels
Big brake kit
Chip the engine
Posted: Fri Apr 14, 2006 10:14 pm
by Andy335Touring
It depends on your budget and what sort of a comprimise/bias you are happy with, a roll cage/bucket seats/harnesses would be advisable for a car used for plenty of track days but you might not want that on a daily driver.
Posted: Fri Apr 14, 2006 11:44 pm
by Lordschleife
m3ben05 wrote:Why not just keep the 318i as a road car then buy a 325 as a track car? The 325 is not much more expensive than the 318is and a lot more powerful.
As far as mods go,
fibreglass panels
Big brake kit
Chip the engine
But a 318is is better in the corners, and surely thats what track days are all about at the end of the day?
Not that 325 is a bad track car, used to have one as my 'ring bitch
Agree with the rest of the stuff, decent brake fluid too
Posted: Fri Apr 14, 2006 11:52 pm
by m3ben05
Fair enough, iv never driven a 318is so i cant comment. I guess it would depend on how much you want to change on the car. I would imagine that a 325 with decent suspension would be better handling than a standard 318is.
Posted: Sat Apr 15, 2006 11:01 am
by M5pilot
Suspension and bushes are your number one upgrades on a track.
Get some GAZ coilovers and Powerflex bushes.
If you then feel you need more power then do some upgrades to the engine/management.
A 325i will be faster on the straights and maybe exiting out of corners but the 318iS will be much better in the corners.
Posted: Mon Apr 17, 2006 11:11 am
by Jem
I want the better balance of the 318is, as I want the car for handling over power. Looks like it's a pretty simple case of sorting the suspension and breaks then, and stripping it out is I want to take it that far.
Posted: Mon Apr 17, 2006 11:13 am
by Dan318-is
m3ben05 wrote:Fair enough, iv never driven a 318is so i cant comment. I guess it would depend on how much you want to change on the car. I would imagine that a 325 with decent suspension would be better handling than a standard 318is.
318is and 325i have the same suspension!! exactly the same!
Posted: Mon Apr 17, 2006 11:43 am
by Lordschleife
Surely the spring rates are different?!
Posted: Mon Apr 17, 2006 1:07 pm
by DanThe
Only the front springs, obviously to account for extra weight up front but the struts, ARB, bushes etc are the same.
The rear ARB can be 12mm on a 325 unless its a Sport or its got M-tech suspension which means it would have 14.5mm like the iS
