Blue Temp sensor on M40 engine...
Posted: Sun Apr 09, 2006 6:02 pm
by Rob_316i
Can anyone post a quick picture of the location of this switch - i would be very grateful. Dont know my way round this engine yet.
Rob
Posted: Sun Apr 09, 2006 7:58 pm
by Gwynleym10
Its on the block, under neath the airflow bellow.
It kinda helps to remove the plastic electical cover thing from it mounts to get at it.
Posted: Tue Apr 11, 2006 4:28 pm
by Rob_316i
Thanks for the reply
Does anyone kno if you have to drain any fluids etc from it to change it or is it screw out, screw in?
Posted: Tue Apr 11, 2006 4:58 pm
by Gwynleym10
no need to drain the fluid, unless its old. Might loose a bit though, and its probably worth bleeding it after as you may create an air bubble.
Posted: Tue Apr 11, 2006 5:06 pm
by Chris-W
Personally I'd take the intake manifold off to make it easier & take the opportunity to replace its gaskets whilst you're at it.
The sensor can be a bugger to get hold off if you lose your grasp on it.
Posted: Wed Apr 12, 2006 11:02 am
by Rob_316i
Cool - i have been advised to clean up the throttle body too so may do it all.
Good advice all - thank you.
