325i sport LSD ....... help
Posted: Mon Apr 03, 2006 10:51 pm
by steve_plym
ive got all 325i running gear off a sport in my 320 i also have a limited slip diff the problem is it just seems to be very worn some times it will work spot on but then other times its having none of it and i end up with one wheel spining.
Any way more the piont dose any one know what i could do to sort it out or even where i could get a set of clutch plates make it like new again or is there an adative you can add to recondition it i just need it to wok all the time also it seems to work better in the dry than in the wet and some times it will just stop working half way through coming out of a junction side ways its a right pain anyway thanks to any one who can help . Steve
Posted: Tue Apr 04, 2006 12:29 am
by bottlecapE30
Frist i would try the recommended redline gear oil i think like 90w i could be wrong? If that doesn't clear it up you can get the parts to rebuild the rear diff from ZF's 2nd life program or www.metricmechanic.com. They are a total pain to rebuild i did one and got the order of the plates mixed up it just slipped forever.
