Wibbly Wobbly
Posted: Sun Apr 02, 2006 8:51 pm
by DazzyA
Recently had some new 17 rims fitted with 205/40's done by the retailer.
Steering is now pretty shakey at all speed's. Took the back and they re-balanced but the problem is still there. Had 16's before with 205/45's and they used to have a little wobbly from 50-60 but otherwise ok.
Can anyone shed any light?
thanks.
Posted: Sun Apr 02, 2006 8:54 pm
by bigdek
do u have spigot rings fitted ?
Posted: Sun Apr 02, 2006 8:56 pm
by E30BeemerLad
probably spigot rings mate
if the centre bore of the alloy hub ain't the same size as the centre of the hub then the alloy doesn't sit true on the hub, so they will balance up fine on the machine in the tyre place, but shake like a shitting dog at 50mph plus.
Alpina reps are famous for it. sometimes the spigot rings supplied with alloys are gash.
shagged track rod ends also induce wheel wobble, but given it all arose with the fitment of the new alloys it's the spigot rings i would look into first.
Worst case scenario is £20 for a new set of spigot rings
hope that sorts her out
Posted: Sun Apr 02, 2006 9:13 pm
by DazzyA
Thank's guys, surely the suppliers should have done this, no?
Posted: Sun Apr 02, 2006 9:21 pm
by E30BeemerLad
they should have but it's not unknown
take a wheel off and see if they have any fitted
Posted: Sun Apr 02, 2006 9:56 pm
by DazzyA
Will do, thanks again mate.
Posted: Sun Apr 02, 2006 10:12 pm
by Taylor325i
This might be what you need :-
http://www.e30zone.co.uk/modules.php?na ... ht=#318517
They solved the problem for me! Just click on the picture for a bigger picture.
Taylor.
Posted: Sun Apr 02, 2006 10:19 pm
by DazzyA
That's interesting, I'm sure they said the spacer's were hub-centric £25 a pair?
How would I tell the diff with the wheel off. Do the universal ones have slotted holes?
Posted: Sun Apr 02, 2006 10:28 pm
by Taylor325i
Yes universal ones usually do have slotted holes. £25 a pair for hub-centric is a lot cheaper than I paid for mine....mine were £140 all in for a set of four (15mm wide polished alloy ones) with 16 longer bolts and postage. I thought I got mine for a fair price - hope I wasn't done.
Taylor.
Posted: Sun Apr 02, 2006 11:31 pm
by DazzyA
Or maybe mine are not what they said.
I'll soon see.
cheers dude.
