Power Steering Banjo Bolts
Posted: Sun Jan 15, 2023 9:01 pm
by G00GIEE
In the process of replacing the knackered M40 engine in my 316i, I've misplaced both of the banjo bolts from the power steering pump.
It's another M40 gone in so I need to find a pair of new banjo bolts and after searching, I have no idea what size they are and so I am unsure where to find the bolts and the washers around them.
Can anyone help me? Does anyone have some or know where I can find the appropriate sized components?
Re: Power Steering Banjo Bolts
Posted: Sun Jan 15, 2023 9:48 pm
by fixedwheelnut
Part numbers on Real OEM.com here ;
M14 x 1.5 x 26 32416852469 still available
M16 x 28 32416783887 no longer available but sure there are others that fit Think a 1 series is the same 32416852470
https://www.realoem.com/bmw/enUS/showpa ... Id=32_0092
Posted: Wed Jan 18, 2023 8:38 pm
by madiran
I have just replaced the power steering pump and intake manifold hydraulic pipe on my '92 E30 318i M40 Touring , the banjo bolts are : hollow bolt M14x1,5x26 32 41 6 852 469 and hollow bolt M16X28 32 41 6 852 470 you will also need the crush washers to fit, two of each: Gasket ring A14X20-ALMG 32 41 1 129 986 and Gasket ring A16X20-CUSN 07 11 9 906 463 , Torque the large bolt to 30 ftlbs/ 40Nm and the small bolt to 26 ftlbs /35Nm. I ordered the parts from https://www.hubauer-shop.de their service was impeccable.
https://www.realoem.com/ and http://bmwfans.info/parts-catalog/
