Red light boot
Posted: Wed Oct 12, 2022 8:39 pm
by Elsalmon
Hi all,
Recently have noticed red light is on as show below. Everything else is off and car has standard locks etc. Have also had a couple of flat batteries recently and wonder if the two are connected as don't think this light has been on previously.
As always appreciate any advice.
Re: Red light boot
Posted: Wed Oct 12, 2022 9:07 pm
by fixedwheelnut
Looks like an Alarm L.E.D but that type were usually fitted in the drivers door above the key slot, have you got any fobs or a strange looking key like the type in this image
https://www.realoem.com/bmw/enUS/showpa ... Id=65_1002
Re: Red light boot
Posted: Wed Oct 12, 2022 10:14 pm
by Elsalmon
Yep we have that lock but no key and this never used it. So thinking something may have happened to wiring to turn it on by itself?
Re: Red light boot
Posted: Wed Oct 12, 2022 11:13 pm
by fixedwheelnut
A flat battery may have reset it, a lot of alarms come on after a power reset as a security in case thieves try disconnecting the power supply.
Re: Red light boot
Posted: Thu Oct 13, 2022 11:23 am
by Elsalmon
Ok thanks. I've had a flat battery in the past just by lack of use and this hasn't happened. It seems to have come on recently and drain the battery. How do I turn it off?
Re: Red light boot
Posted: Thu Oct 13, 2022 2:47 pm
by biffer
Try pulling fuse no. 28 in the fusebox- i read somewhere this system runs off this fuse along with the electic aerial and cig-lighter.
Re: Red light boot
Posted: Thu Oct 13, 2022 6:35 pm
by BenHar
Take the bulb out?
Ben
Re: Red light boot
Posted: Thu Oct 13, 2022 7:13 pm
by DanThe
Every cabby ive done restoration type work on ive removed the wiring for these, usually by cutting it off just behind the panel
