Gearbox and Diff Oil - 325i Auto
Posted: Mon Oct 25, 2021 11:47 am
by Bavarian1988
Hi guys
Would anyone happen to know which oil is recommended to use when replacing the gearbox and diff oil on my 1988 325i Auto Cabriolet?
I carried out a VIN check on the vehicle and it showed that it has a 25% LSD?
Any suggestions will be greatly appreciated
Re: Gearbox and Diff Oil - 325i Auto
Posted: Mon Oct 25, 2021 11:59 am
by paultv
Use this for your LSD
Syntrax Limited-slip SAE 75W-140
Not sure about the auto box - anyone?
Paul
Posted: Mon Oct 25, 2021 12:17 pm
by Bavarian1988
Much appreciated Paul
Yes just need to know the oil for the gearbox
Posted: Mon Oct 25, 2021 7:14 pm
by BenHar
Posted: Mon Oct 25, 2021 7:25 pm
by Bavarian1988
From the Wiki page on the site, it states that automatic boxes should use 'Castrol Dexron III' however this has now been replaced with 'CASTROL TRANSMAX ATF DX III MULTIVEHICLE.'
Is someone able to confirm?
Many thanks
Posted: Mon Oct 25, 2021 8:02 pm
by flybynite
Bavarian1988 wrote: ↑Mon Oct 25, 2021 7:25 pm
Many thanks
Haven't got or had an auto e30 but just put '88 325 into Castrol oil finder and it comes up with
Castrol Transmax ATF DEXRON®-VI MERCON® LV Multivehicle
Alternative
Castrol Transmax ATF DX III Multivehicle
So I guess you could use either
Posted: Mon Oct 25, 2021 8:59 pm
by tha881
I would double check the LSD is still fitted, although it was fitted from new it could have been swapped at some point
Posted: Mon Oct 25, 2021 10:36 pm
by 30316
Filtering down further on the Castrol site it looks like only Castrol Transmax DX III meets ZF transmission spec. E30 only used auto tx made by ZF. Up to now I have only used Dexron III spec oil. Do not forget to do a proper service you need to change the filter as well.
Posted: Mon Oct 25, 2021 11:32 pm
by Bavarian1988
Thank you for all the suggestions guys, much appreciated.
Posted: Tue Oct 26, 2021 9:13 am
by oilman
Just a Dexron II or Dexron III ATF for the autobox, does not have to be Castrol but stick to a reputable brand and all will be good.
Cheers,
Guy
Posted: Tue Oct 26, 2021 8:19 pm
by Bavarian1988
Thanks oilman
