Clio steering UJ
Posted: Sun Mar 28, 2021 6:56 am
Hi what year Clio is it to use the steering UJ from for the E30??
I’ve found a 2007 one...
It's the Corsa joint I've installed a few times.Extremepower3918 wrote: ↑Sat Apr 10, 2021 4:43 pmDo you mean corsa U joint like in the wiki? You can use the brake servo from a clio
https://www.e30zone.net/e30wiki/index.p ... ng_Linkage
MAYBE I DID MEAN CORSABlack_Op_88 wrote: ↑Sat Apr 10, 2021 11:42 pmIt's the Corsa joint I've installed a few times.Extremepower3918 wrote: ↑Sat Apr 10, 2021 4:43 pmDo you mean corsa U joint like in the wiki? You can use the brake servo from a clio
If this fella has done something with a clio joint it might be an alternative for someone.
On the other hand maybe he ment Corsa not Clio.![]()
