M20 tapping
Posted: Tue Feb 07, 2006 10:21 am
by N4SBM
what can it be, its very loud, have been told it could be cam, but does anyone have any other suggestions on how resolve.
much appreciated!!
Posted: Tue Feb 07, 2006 10:25 am
by Steviec
The tappets may just need adjusting.
Posted: Tue Feb 07, 2006 11:22 am
by JazzMan
I've been told it could also be the fuel injectors. A lot of M20's tend to be tappy. Mine was too.
First stop check the tappet adjustment
Posted: Tue Feb 07, 2006 11:27 am
by massive
JazzMan wrote:I've been told it could also be the fuel injectors. A lot of M20's tend to be tappy. Mine was too.
Tappets are non-adjustable on M20!
Try the valve clearance first - common problem on these and they do get loud! Look in the Articles on how to do it.
Posted: Tue Feb 07, 2006 11:28 am
by N4SBM
Try the valve clearance first - common problem on these and they do get loud! Look in the Articles on how to do it.[/quote]
THANKS, MUCH APPRECIATED
Posted: Tue Feb 07, 2006 12:20 pm
by kenwoir
[/quote]
[/quote]
I was speaking to a BMW specialist a few weeks ago and he was saying the tappets are non-hydraulic and can be adjusted by loosening the small nut on the top, tighten the screw up then lock the nut up again, obviously using feeler guages for the correct setting... i'll stand corrected tho if im wrong/be given wrong info
Posted: Tue Feb 07, 2006 12:24 pm
by JazzMan
kenwoir wrote:I was speaking to a BMW specialist a few weeks ago and he was saying the tappets are non-hydraulic and can be adjusted by loosening the small nut on the top, tighten the screw up then lock the nut up again, obviously using feeler guages for the correct setting... i'll stand corrected tho if im wrong/be given wrong info
This is what I had always thought, we shall see once my engine is running again as I need to do mine
Posted: Tue Feb 07, 2006 12:42 pm
by Steviec
The tappets ARE adjustable on the M20 engines, ive just had mine done.
Posted: Tue Feb 07, 2006 12:43 pm
by gcorky
the tappets or VALVE CLEARANCES are 100 percent adjustable via the eccentric cam and locknut.
m40 engines ARE NOT,if they ra tappin its dosh time.
Posted: Tue Feb 07, 2006 12:51 pm
by gcorky
tapping or ticking are very different.
ticking at a certain rpm may well be injectors -mine do at around 2k
constant tick may well be valve clearances or AKA tappets
tapping loudly could well be cam wear -remove cam cover to inspect!!!!
oil/filter changed recently?
Posted: Tue Feb 07, 2006 12:59 pm
by N4SBM
gcorky wrote:tapping or ticking are very different.
I've have recently changed my oil/filter, and engine flush but no glory,, can you recommend what i can do!!
Posted: Tue Feb 07, 2006 1:03 pm
by kenwoir
i have ticking/tapping, whatever it wants to be called, when accelerating, best way to describe it is it's like the sound of the old fiesta engines, if that makes sense. It's not what you would call loud and with the radio on it cant be heard. I'm gonna adjust the tappets when i change the rocker cover and see how that goes.
m20 tappin
Posted: Tue Feb 07, 2006 1:24 pm
by N4SBM
kenwoir wrote:i have ticking/tapping, whatever it wants to be called, when accelerating, best way to describe it is it's like the sound of the old fiesta engines, if that makes sense. It's not what you would call loud and with the radio on it cant be heard. I'm gonna adjust the tappets when i change the rocker cover and see how that goes.
thats what it exactly sounds like geez, let me know how you get on, then i could do the same..
Posted: Tue Feb 07, 2006 1:30 pm
by gcorky
remove cam cover -inspect lobes for ridges or pitting.could also check valve clearances at same time.
is it more prominent inside the car?if it is remove horn push and plug the steering column hole.
also may seem daft but ive seen it !are the spark plugs tight ???sounds quite nasty with a loose one!
exhaust manifold ok -no broken studs,leakin
just a few ideas because its hard to diagnose without seeing vehicle.
Posted: Tue Feb 07, 2006 1:34 pm
by kenwoir
i'm 99% sure its the tappets, i had the rocker off when i was servicing the car and all looked sweet within and fitted a new gasket, all studs are fine and tight, new plugs are ok and tight, new manifold gaskets fitted also and all sealed well so i'd be sure i can eliminate all of them.
Will let you know asap mate
THANKS!!!
Posted: Tue Feb 07, 2006 2:03 pm
by N4SBM
kenwoir wrote:i'm 99% sure its the tappets, i had the rocker off when i was servicing the car and all looked sweet within and fitted a new gasket, all studs are fine and tight, new plugs are ok and tight, new manifold gaskets fitted also and all sealed well so i'd be sure i can eliminate all of them.
MUCH APPRECIATED THE ADVICE...
Posted: Wed Feb 08, 2006 6:17 am
by kenwoir
GCORKY i really thot you were on glue when i read this yesterday..lol just kidding mate, but when i was driving home from work i drove with my head out window, then back in with the window up and it is more prominent inside the car so i pulled the horn push off and the ticking got a bit louder, stuck my finger over the wee hole on the end of the steering column and BINGO, no more ticking to be heard. Good job fella, makes for a nice quiet drive now.
Posted: Wed Feb 08, 2006 8:11 am
by JazzMan
Simple, yet effective! I like it
Posted: Wed Feb 08, 2006 8:15 am
by Steviec
I stuck a bit of bluetack on mine, and what a difference!
bung
Posted: Wed Feb 08, 2006 8:19 am
by beardymat
when i changed my steering wheel to a tech 2 on mine it had a piece of dum dum over the hole in the column,i thought "whats that sh@t doing in there" and didnt put it back but as i havnt driven it yet i cant say if it ticks or not.
at least i know now
Posted: Wed Feb 08, 2006 11:06 am
by gcorky
glue lol ,cheers
Posted: Wed Feb 08, 2006 12:54 pm
by Motorhole
To determine whether tapping/ticking is from valvetrain or injectors, use a long screwdriver, place the blade on the area in question (For instance, rocker cover) and put your ear to the handle, much like a stethoscope!
Injectors shouldn't tick when engine braking above arouns 2500rpm as they shoudln't be firing, although they could be difficult to hear anyway!
