E30 Trim restoration
Posted: Fri Aug 21, 2020 2:53 pm
by SamD02
Hey
Does anyone know the best way to restore faded bumper trim and grill plastic?
I’ve seen videos of people just spraying them? Do I need to sand them down a bit before and primer them too?
Re: E30 Trim restoration
Posted: Fri Aug 21, 2020 4:31 pm
by Cloggy Saint
I use Gtechniq C4 Permanent Trim Restorer. It's not cheap but it does the job.
Posted: Fri Aug 21, 2020 4:53 pm
by SamD02
Ok cheers I’ll have a look at it.
Posted: Fri Aug 21, 2020 5:08 pm
by Brianmoooore
The professional way of restoring black plastic trim is with a heat gun. You have to get the trim hot, but not too hot, and the colour will be restored, but it takes experience to get it just right.
Posted: Wed Aug 26, 2020 11:04 am
by Moz
Gtechniq for me too, just be sure to wipe it off as instructed as a little longer and it leaves a film over the top that is very hard to remove!
Posted: Wed Aug 26, 2020 11:15 am
by paultv
Boiled linseed oil...lasts for 12 months....and you can do your cricket bat too !!
Half litre bottle will last forever!
Paul :-)
Posted: Wed Aug 26, 2020 5:33 pm
by BenHar
Raw linseed oil for cricket bats.
Ben
Posted: Wed Aug 26, 2020 6:44 pm
by acme15
Linseed oil lasts about a week before the trims start going patchy and fading again, if the car lives outside and gets rained on etc. It might last a few months if the car is parked indoors and never goes anywhere.
Posted: Wed Aug 26, 2020 6:47 pm
by acme15
Anything you do will be temporary. Either paint them with satin or matte black direct to plastic paint, use a heat gun with care, or buy new ones.
Nothing you wipe over them will last long. Even that expensive C4 "permanent" trim restorer only lasts a year or so at most. No idea why they are allowed to call it permanent.
by paultv
I stand corrected sir...
"Howsthatt" !!!
Paul :-)
Posted: Wed Aug 26, 2020 6:49 pm
by paultv
It has to be the boiled variety...lasts really well... used it for years...
Paul :-)
Posted: Wed Aug 26, 2020 6:52 pm
by acme15
Paul :-)
Were your trims just not that faded to begin with? Do you only drive your car in the dry and keep it in a garage? Or do you re-apply it daily? Haha
Its also really greasy.
Posted: Wed Aug 26, 2020 7:17 pm
by Brianmoooore
Paul almost certainly has the most 'driven' E30 on the zone. Far from a garage queen.
Posted: Wed Aug 26, 2020 7:32 pm
by paultv
I use it twice a year.....but I think you've made up your mind already.....it's just free advice from someone who uses their car daily...in all weather's....
Good luck buddy.
Paul :-)
Posted: Wed Aug 26, 2020 8:17 pm
by Radar
I’m going to try applying Avalon King’s Amourshield ceramic coating. Mine have faded to a very pale grey so not much to lose as anything will bea an improvement
Posted: Thu Sep 03, 2020 5:04 pm
by e30-EVN
I can also vouch for this technique. I did it on my vRS a few years ago and it worked very well
Posted: Thu Sep 03, 2020 5:43 pm
by Cloggy Saint
I remember peanut butter was touted here in the past, can't vouch for it though.
Posted: Thu Sep 03, 2020 6:50 pm
by Brianmoooore
The required oils are already in the plastic. The heat gun brings them to the surface.
Posted: Thu Sep 03, 2020 7:38 pm
by e30-EVN
Yeah I've heard of people using peanut butter aswel. But as Brian said, the heat from using a heat gun activates the oils already there and makes the trim pop like new again
Very effective
Posted: Sat Sep 05, 2020 8:20 am
by Satan
Trouble is that you will then need to remove the squirrel teeth marks from the trim...........
