Leaky Injetor
Posted: Tue Oct 15, 2019 9:54 pm
by Sligmaaaa
Hey, here I go again asking for your help :
So after doing a quick check up in my M40 engine bay I noticed that the first injector (closer to the transmission) was wet looking so I guess there goes an injector leak which also explains the strong fuel smell around the engine bay and the interior.
Will new seals repair the problem? Or that's a sign of a bad injector?
As always your help is appreciated!
Re: Leaky Injetor
Posted: Tue Oct 15, 2019 11:07 pm
by Cloggy Saint
You may be lucky and just need new O rings. Is the car driving as it should?
Re: Leaky Injetor
Posted: Tue Oct 15, 2019 11:29 pm
by Sligmaaaa
Power wise the car is ok , revving all the way to 6 and half no problem at all
Mpg is 28ish with mixed driving
However the car sometimes is having a rough idle, not sure if that's linked to the leaking injector
Re: Leaky Injetor
Posted: Wed Oct 16, 2019 9:01 am
by aimlessrock
personally, unless you know the injectors were overhauled i would removed them all and have them professionally cleaned- injectortune refurbishedl mine for about £12 per injector.
Re: Leaky Injetor
Posted: Thu Oct 17, 2019 2:33 pm
by HJ1981
It MAYBE the top O-ring where the injector and fuel rail connect.
I have personally seen M20 injectors that leaked from the body, those are not repairable, rare but it happens.
Have the injectors removed and sent out for proper ultrasonic cleaning, flow tested and checked for leaks and new seals.
Re: Leaky Injetor
Posted: Thu Oct 17, 2019 5:36 pm
by Sligmaaaa
Had my car delivered for intake manifold inspection today.
Every rubber was replaced and also the injectors was cleaned, No more gasoline smell
Cost 70 euros!
Re: Leaky Injetor
Posted: Fri Oct 18, 2019 12:13 pm
by martauto
Sligmaaaa wrote: ↑Thu Oct 17, 2019 5:36 pm
Cost 70 euros!
Good result mate and ask about anything anytime as much as you like , thats why the zone is here mate
Re: Leaky Injetor
Posted: Fri Oct 18, 2019 4:04 pm
by Sligmaaaa
Thank you Mart!
